Best suspension upgrade for street use?
Old Jun 5, 2003 | 02:50 PM
scyzoryk's Avatar
Are subframe connectors the best street use suspension upgrade? or there is something better. I want to improve cornering..
sebastian
Old Jun 5, 2003 | 02:58 PM
madwolf's Avatar
Well I'd say subframes are definetely the first suspension mod I'd do on an F-body, but whether it will improve cornering or not, I'm not sure. Probably some springs and shocks would be better for that.
Old Jun 5, 2003 | 03:00 PM
SloMofo's Avatar
and good tires to go along with em
Old Jun 5, 2003 | 03:03 PM
rskrause's Avatar
Moderator
Better tires are the most effective change, but most people don't think of these as "mod" and the amount of improvement will depend on what you already have. Better springs are the single best suspension "mod" in the usual sense. Either Eibach "Pro" if you want a lower ride height or 1LE if you want stock ride height.
Better shocks to go with the springs are a big help.
Rich Krause
Old Jun 5, 2003 | 03:20 PM
snorkelface's Avatar
For the best improvemnt in this category, for the least amount of money would be sway bars. Go talk to the guys in the AutoX section about which combo would work best for you.
Old Jun 5, 2003 | 03:45 PM
Gripenfelter's Avatar
I ordered a set of Double Diamond SFCs from Darren at info@sybersport.ca and they were by far the best suspension mod I've done. Also got them for $185 u.s. INCLUDING shipping.
Old Jun 5, 2003 | 04:27 PM
jkipp84's Avatar
FWIW, Strano told me if he was limited to a single suspension mod, it'd be a good set of shocks (Koni adj up front, Bilstien's out back).
Old Jun 6, 2003 | 08:14 AM
IDOXLR8's Avatar
This should get you started
Subframe connectors
Strut tower brace
Eibach springs and Bilstein shocks
Bigger Sway bars (Either BMR or Spohn)
Old Jun 16, 2003 | 09:27 AM
ZZtop's Avatar
I have pretty much all the suspension mods that have been listed except for the subframe connectors. The car handles and rides awesome, but when you hit a bump its got its got a few rattles. I think SFC's will help with this and stiffen it up for the track, so that is my next mod.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
jp2002ls1
Aug 6, 2002 11:15 AM
