How Can I find out what size Gears I have in my Rear End Differential?
Old Jun 4, 2003 | 06:12 PM
LeeS's Avatar
Hi Guys!
How Can I find out what size gears in the Rear End Differential ?
My car is a 1997 Z28 with Automatic Transmission.
Thanks Lee!
Old Jun 4, 2003 | 06:22 PM
Derrick Redd's Avatar
Look in your glove compartment. They have some codes listed. GU2 = 2.73 and GU5= 3.23. Another way is to look at your shifter. If you have a visible 1 on your gear selector you have 3.23. If not then it's 2.73.
Old Jun 4, 2003 | 08:49 PM
zomowiec's Avatar
You can also spin you wheel for one full turn and count how many times your driveshaft turned. If it did 3.23 turns, your gears are 3.23
Old Jun 4, 2003 | 10:39 PM
JKDZ28's Avatar
where your shifter is if it says:
OD - D - 2 - 1 then you have 3.23 gears
if it has no " 1 " then its 2.73
also check the glove box for gu2 or gu5
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
