How to remove !air?
Old Jun 3, 2003 | 09:36 PM
1994CamaroZ28's Avatar
How to remove !air?
Just wondering what all you guys removed when you get rid of your air pumps?
Old Jun 3, 2003 | 10:31 PM
94GrayV6's Avatar
Just pull the fuse for it, and the air pump assembly. It is attached to the front of the block.
Old Jun 3, 2003 | 10:34 PM
Last time i removed the fuse it threw a code, so you can only remove the actual pump or can you remove the rest of it? any guides out there for those whove done it before?
Old Jun 3, 2003 | 11:07 PM
94GrayV6's Avatar
Ahh yes, sorry about that code thing. I had mine programmed out with pcmforless.
Old Jun 4, 2003 | 12:52 AM
revtime's Avatar
Leave the fuse in and you should not have a problem.
OBD1 only.
Old Jun 4, 2003 | 01:11 AM
stevil's Avatar
guide
Well, sort of a guide. You can program the AIR code out, or use a resistor to fool the PCM, 100 ohm 10 watt should do it. Remove the pump, plug the holes in the airbox and exhaust manifolds, etc.
DirtyDaveW
Dec 1, 2016 05:37 PM
rjc1629
Jan 27, 2015 10:46 AM
95chwagon
Jan 13, 2015 09:19 PM
97SSdude
Dec 31, 2014 07:43 PM
CamaroZBoy
Sep 9, 2002 10:33 AM
