what do you guys think about the Power Stop Rotors?
Old Jun 2, 2003 | 09:11 PM
Camaro_Maniac63's Avatar
Arrow what do you guys think about the Power Stop Rotors?
Are they worth the money? Also, what kind of pads would you recommend? I have heard good things about the Hawk Pads, but just wanted to ask you guys about your opinion before getting them. Thanks.
Old Jun 2, 2003 | 09:49 PM
zomowiec's Avatar
My friend had Powerstop rotors on 3000 GT and they all cracked so i wouldn't recommend them but i have KVR for about one year 20K miles and they are perfect paid about $430 for a set with cadium coating
Old Jun 3, 2003 | 04:18 PM
D Guess's Avatar
I had them on my 99 Formula for about 10,000 miles or so before I sold it. I didn't have any problems with it other than the ugly gold cadmium color. I painted them black. I think you can get them in silver.
I used stock pads with mine.
Also, I've heard good things about the KVR blanks. You'd probably be better off going with those.
Old Jun 3, 2003 | 04:28 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
blank rotors > slotted rotors > cross drilled rotors > CD'ed and Slotted rotors.
post from another thread because i'm too lazy to explain it again-
just weed through it and find the relivant info
I posted this in the LS1 tech section and I am kind of hoping some guys here can give me some more insight. 95% of this info came from one guy and I would like some more "in depth" opinions about this stuff.
There has been a growing "slotted vs cross drilled vs flat vs do it yourself" kind of thing going on and I would just like to start this post for an open ended kind of discussion regarding air flow, cooling, and practical uses.
Thanks guys-
Originally posted by mark@ssbc
No, slotted rotors do not eat pads faster. And they do not warp very fast since the slots help keep them cool. Of course, if you slot a cheap rotor, then it's still a cheap rotor and it may indeed warp relatively fast. We don't drill our rotors since drilling cause stress fractures in the rotors, shortening it's life span.
Click here to see cracks in drilled rotors.
Mark,
Not to nitpick, but i would like to throw in my two cents here.
I work at TRW automotive in their Livonia facility, which is their Braking systems research and development facility.
First off, I would like to say I am a co -op student there and not a full time engineer till i get out of school (assuming we both want me to work there at that time). WIth that said, most of this information is second hand and comes fom the senior engineers. Most of it actually come from my former supervisor who was a big autocross guy and former F-body owner.
Slots and cross drills are not for cooling and provide a very minimal amount of cooling. the majority of the cooling comes from the vents and the size of the rotor and its thickness.
The vents can create some pretty nice air flow inside and around the rotor.
The slots and holes do not have a significant amound or air flow around them. Althought this can be debated since real world air flow in that region is a stab in the dark on a good day. It is pretty well agreed upon that those slots and hole do very little for cooling though. The air in there is almost stationary when compared to the vents and the air along side the rotor (particularly outboard braking plate). The air is flowing from left to right (when looking at the rotor head on- looking at the wheel stud holes). Very little air is flowing from the inboard to ourboard rotor plates or vice versa. The air inside the vent holes is pretty stagnant in there compared to the air along the outboard rotor and air in the vents. The vents can work because they utilize the air flowing from left to right, not "into" the rotor. They are like little fans.
Plus the amount of surface area has probobly trippled or quadrroopled with these vents. here is now two more surfaces in the middle (effectivly doubling surface area right there) and the additional surface area of the 4 surfaces of the vent.
If i had to guess, I bet that there is VERY little air flow inside the wheel well t begin with- and particualry under our cars relative to most other cars. The low stance and air dam really should do a good job of making sure air doesn't go crazy under there.
As far as breaking power goes, they will reduce your breaking power since a good percentage of your friction is lost. i'd guess around 10% of your pad is no longer creating any friction.
These slots and holes are for releasing gasses that build up under high heat and pressure of panic stops (or aggresive driving). With the pads used in todays vehicles, there are EXTREMLY little gasses prodeced, if any at all. If there is any, its prety much negligable.
As far as drilling your own (did i read that somewhere?), I am pretty sure.
a. slotted/cross drilled rotors are thicker/stronger than OEM
b. it has to be PEFRECTLY balanced or life will be ****ty
c. It is extremely hard to drill evenely, effectively and safely.
You have to drill correctly (dont crack the rotor!), symetrically (dont throw it off balance) and you CANT HIT ANY OF THE VENTS!. doing the last two tegether will prove to be a challenge since most rotors have a prime number (hence odd) number of vents. This is done purposely do make as FEW LINES of symetry as possible. Less lines of symetry = less noise for a mutitude of reasons over my head, I didn't really get it when my boss explained it to me. So drilling symeticrially and not hitting nonsymetrical vents might prove to be a mathematical nightmare!
In this long winded responce, i kind hoped to get at this. Slotted and cross drilled are realy only good for appearance mods. If anything they will probobly warp and/or crack faster with all things being equal (which they are not for obvious reasons)
Personally, I am going to try some stuff out and see what happens. Although it probobly wont be as cost effective as the LS1 or C5 brake upgrade- I am drawn to doing it. I guess my natural curriousity is doing it to me. I am going to attempt to make two ducts (one for each front rotor) to cool the inboard rotor. Kind of like "ram air" to the rotors if you will. I will do some measurements to see how well it stops- although i cant really guarntee accuraccy. I am also going to swap in the most exensive/best brake fluid i can find and see what that does- maybe even find some crazy way of cooling it Then i'll probobly just do the LS1 brake upgrade and get some Hawk Pads. Thats probobly the best bang for the buck (well, the majority of you guys already have the "LS1 brake upgrade."
With the above said, a set of high quality "solid" vented (99% are now a days) rotors would probobly suit you best for your application. Who makes them or what they cost is beyond me. I was just doing some late night LS1 reading tonight and stumbled across this. I would't worry too much though about the car, warped rotors are pretty common on LS1's. Hell a drive through a puddle/car wash after a long drive can do it.
Mark please dont (and I hope you didn't) take this as an attack on you or your buisness, merchandise or expertise. I was really hesitant to type all of this seeing how you are a new supporter of this website. I am really all for supporters of this site and encourage/suggest to member to buy from here whenever possible.
here is another thread about rotors that I wrote a few days ago, cant remember if its relavent or not... i think its mainly just production methods.
http://web.camaross.com/forums/showt...r&pagenumber=2
Anyway, its amost midnight, i'm tired and its raining so I think I am going for a jog. I've been staring at rotor blueprints and talking about them too much. I think its bordering unhealthy at this point
please pardon my terrible spelling and -i'm sure- numerious typos.
InfernalVortex
Jan 17, 2015 09:35 AM
bossco
Nov 29, 2014 10:18 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Red97LT1
Aug 7, 2002 05:45 PM
