Permanent Water Spots?
Old Dec 23, 2001 | 12:33 AM
JoshWhite's Avatar
Post Permanent Water Spots?
Hey Guys,
My windows are very badly spotted and streaked. I've tried every trick I've heard of: hot water, vinegar, steel wool, Eagle's 20/20 and even Z12 Glass Polish. Is there anything left for me to try. Nothing seems to have even made a dent. Is my only remaining option to replace the glass?
Thanks,
Josh
2000 Camaro M5 - Y87
Bright Rally Red - Stock
Old Dec 23, 2001 | 02:05 AM
NAKSTOCKZ28's Avatar
Post
windex or windex with steel wool, finer the woolthe better
Old Dec 23, 2001 | 12:06 PM
KevinSS's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by JoshWhite:
Hey Guys,
Thanks,
Josh
</font>
Z-12 will remove any water spot from any window if you use it right, for a bad case like yours you have to use pressure with your hand to remove the spots, take a cotton cloth and put a quarter size dot of Z-12 on it, rub a 2 to 3 inch square area using back and forth motions using a lot of pressure pressing down hard on the cloth, keep rubbing it back and forth until the glass starts to squeak, at this point the glass is free of spots. Repeat this until you have covered the entire glass area. You can not just apply Z-12 like wax and expect it to do anything, you must use pressure and rub very firmly for the abrasives in the Z-12 to grind off the water spots.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
Old Dec 23, 2001 | 04:56 PM
JoshWhite's Avatar
Post
WOW! Thanks, Kevin. The Zaino took the water spots right off using the method you described.
Thanks again!
Old Dec 23, 2001 | 05:44 PM
KevinSS's Avatar
Post
Thanks again!
</font>
I have never seen it fail, just gotta know how to do it.
96 Black Impala SS
www.zainobros.com
Remember #3
meissen
Aug 11, 2015 06:05 AM
MikeWhitener
Aug 2, 2015 06:17 PM
Boss002
Jul 24, 2015 10:47 AM
Fastbird93
Jul 11, 2015 04:37 PM
Boss002
Jul 9, 2015 03:33 PM
