Slow start sometimes
Old May 27, 2003 | 09:55 PM
GrdLockV6's Avatar
I don't really know much about starter and ignition systems... so I gotta question. I have 126k miles on the clock, and I just got this TA a few weeks ago so I don't know what's recently been replaced. But anyways, about 1 out of 5 times I start the car, it takes about 3 or 4 seconds to start. The rest of the time it starts right up, but sometimes it sits there and cranks for longer then it should.
What could the possible problem be for this? If something's about to die on me, I'd like to go ahead and replace it now, then to have my car not start on me when I'm needing to go somewhere.
Oh, and while I'm at it, is low oil pressure normal for LT1's? On a cold start the oil stays above 60psi, but after the block warms up it often goes down to 20psi, just a little ways above the red mark when I idle. That normal, or could my oil sender or somethin be dying? Or possibly a leak... actually probably I'm pretty sure I got the intake manifold leak that I haven't gotten around to fixing yet.
Old May 27, 2003 | 10:19 PM
Xride's Avatar
my car does the same thing. I have no idea what it is, but sometiems it takes 10 seconds of cranking ot start, mostly if its real hot like at the track though.
Old May 27, 2003 | 10:25 PM
bradpreece95z28's Avatar
here is what you could look for
as far as the oil pressure , thats about right for an lt1. mine is a little higher than that, but the general rule of thumb is 10 psi for everyu 1000 rpm.
the long start or delay is more than likely a fuel issue. i would say check your fuel pump and fuel filter. then go from there. I would venture to say that your pump may be okay, but the filter is probably shot man.
rideordie
Nov 5, 2019 04:52 PM
jb4xx
Feb 2, 2015 10:00 PM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
DETROIT_AREA_00_SS
Aug 7, 2002 10:54 AM
