Electrical Problem, Need HELP!
Old May 25, 2003 | 11:18 AM
JBRedZ28's Avatar
I have a 94 Z28 that has a voltage drop (to around 11 or so) when I turn on any combination of the AC, headlights, and rear window defogger. I had a local auto parts shop test my alternator in the car and it tested at 25 peak Amps (well below the 140 it is rated for). I replaced the alternator with a remanufactured AC-Delco and it read 19 Amps with there testing equipment. Since I had the original out of the car they tested it inside their shop and it tested fine. I then thought it may be a bad battery. It is a 10 month old Maxx-75 battery from Walmart. I figured it wasn't the battery because the voltage drop is while the car is running but still took the car to Wal-Mart. The battery tested good and bad both inside and out of the car at different times at 2 different Wal-Marts. I ended up having the battery replaced for free under warranty because the battery was in question. Well, I still have the voltage drop when I turn on the accessories. I had a local dealership replace my starter a month ago because the solenoid didn't disengage and it fried the motor literally. After all this, what do you guys think is the problem? A bad ground? Something the dealership did when they replaced the starter? Thanks in advance for any thoughts.
Old May 25, 2003 | 12:44 PM
JBRedZ28's Avatar
Anyone?
Old May 25, 2003 | 01:45 PM
Zepher's Avatar
Does it drop to 11 on your dash gauge or on the test equipment or both?
Old May 25, 2003 | 03:25 PM
JBRedZ28's Avatar
I know it drops for sure on my gauge. Not sure about the voltage on the test equipment. I only know the test equipment showed the system putting out 25 Amps when it put my engine under a load (I guess that is what they call it).
Old May 25, 2003 | 07:47 PM
Zjoker's Avatar
Lightbulb
Do you have an underdrive pulley and is the voltage drop at idle Rev the engine to about 1500-2000, if its go to 13.4-13.9 there is nothing wrong
Old May 25, 2003 | 08:07 PM
funina91ss's Avatar
mine is doing the same thing I have also had it tested with good and bad results. does yours charge fine when you first start it up then when it gets warm it starts acting up? I did move my battery to the sparetire well.(thats when I noticed my problem) I even put a ground strap on with no luck. and had the alt. rebuilt(one I had already) I have a brand new red top optima 720 CCA battery and I am about to give up on it. I noticed when my fans or any other high power acc. is on it will drop down real low. even If I rev it up it goes up slitghly but not what I should. And sometimes if I turn my fog lights on then turn it the rest of the way it the headlights wont pop up...Good Luck if I found out anything I will let you know.
Old May 25, 2003 | 11:18 PM
JBRedZ28's Avatar
funina91ss: My car starts fine. I only see the voltage drop when I turn a few things on to put a heavier load on the system.
Zjoker: I don't have an underdrive pully. The voltage drop is only at idle but in 9 years of owning and driving this car, I have never seen this happen. The voltage does go back up to normal when I rev the engine.
Old May 26, 2003 | 11:30 AM
JBRedZ28's Avatar
bump
liamcg97
Nov 25, 2019 05:55 PM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
BMX Dad
Jan 23, 2015 07:00 PM
97z28k&N
Jan 9, 2015 04:58 AM
