what causes burnt valves?
Old May 25, 2003 | 08:26 AM
anasazi's Avatar
i was talking with my mechanic friend and he said open longtubes would burn valves. i already asked if our valves will burn with open longtubes and was told no, so what causes burnt valves? is there something special about the LT1 so that the valves won't burn with open longtubes and normal engines they will? what are the symptoms of a burnt valve?
Old May 25, 2003 | 08:35 AM
I thought you already asked this
Shorty headers might be a of a little concern, but not long tubes. Do you think all the cars at the strip with open headers are burning their valves? Rhetorical answer=no.
The problem is if the valves cool off too rapidly because of short exhaust piping. Not going to happen with long tubes.
Old May 25, 2003 | 08:38 AM
anasazi's Avatar
ok thanks
yea last night i asked if i would burn my valves, now i'm wondering what that even means
so i'd assume even at high RPM's it wouldn't hurt anything... hmmm i think its time for a highway run before i take it to the exhaust shop...
Old May 25, 2003 | 10:22 AM
Mindgame's Avatar
Never seen an exhaust problem that resulted in burned exhaust valves. Now if the valve isn't making contact with the seat (improper adjustment etc.) it will burn cause it can't transfer the heat.
The backpressure thing should be categorized with alot of other "urban legends".
-Mindgame
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
dolfan324
Jul 17, 2015 10:34 PM
