is it safe to run a bigger jet?
Old May 25, 2003 | 06:26 AM
My84Z's Avatar
if i run a 100 shot of nitrous and the 150 for the gas is it safer or either way does the same thing?
Old May 25, 2003 | 06:31 AM
My84Z's Avatar
the jets are nitrous 52 fuel 35
Old May 25, 2003 | 12:47 PM
My84Z's Avatar
someone tol me it would be fine anyone else?
Old May 26, 2003 | 12:18 AM
LPEdave's Avatar
That's a pretty rich setup, and would generate less power than a properly tuned set of jets. So I guess the answer is that it's safer for the engine, since there's less power. But you'd probably be better off dropping both jets down in a proper ratio, rather than just adding more fuel if you want less power.
Dave
Old May 27, 2003 | 01:16 AM
KTamez's Avatar
Too much fuel can actually be just as harmful as not enough. With excess fuel, its possible for the fuel to get trapped under the piston ringland, and then proceed to ignite, effectively breaking the ringland (which is notably the weakest point in many stock Hypereutectic pistons). Running a slightly larger fuel jet probably wouldn't cause this sort of problem, but FYI, the factory suggested Settings tend to be plenty rich/safe on their own. No need to add even more fuel to an already slightly rich mixture.
JM $.02
Old May 27, 2003 | 07:17 AM
My84Z's Avatar
Thanks do you think that will be to rich?
Old May 28, 2003 | 01:19 PM
KTamez's Avatar
Not sure what ya mean? All I was saying was run the system at its recommended jettings and you'll be fine.
Good luck!
DirtyDaveW
Dec 1, 2016 05:37 PM
Feffman
Oct 9, 2015 05:42 AM
Jan 23, 2015 01:13 PM
skittlez87
Dec 29, 2014 03:23 PM
