12 bolt, 9 inch alternatives?
Old May 25, 2003 | 04:15 AM
ollie-99's Avatar
are there any cheaper options other then those 2?
them are both super expensive and i was wondering if any other rear end would fit on there etc
thanks
Old May 25, 2003 | 04:38 AM
bunker's Avatar
No you **** the 9" could be had for 1500US with all new parts, I'll let you konw if you are interested.
Old May 25, 2003 | 06:24 AM
indy500ss's Avatar
I am confident that those are your only two options! You can get almost any rear to fit, but it will take extensive modifications, definatly more than a 12 bolt or 9" would run you. If you are not looking to spend all that money, try a gear swap, and get a T/A stud girdle kit. Getting a C-clip eliminator is also another option, but I do not know the details of this install or a price.
Old May 25, 2003 | 11:01 AM
TCAL95Z's Avatar
try this place.
www.extremechassis.com They are selling a 8.8 with moser axles and a auburn posi for $1700. You can also use your abs with this one. I don't know a thing about them but it looks to me like it's about $500 cheaper than a strange 12 bolt
Old May 25, 2003 | 11:13 AM
Larnach's Avatar
That's awesome, now we can use the Torsen T-2 in something that can take around 900+rwhp.
Old May 25, 2003 | 11:25 AM
TCAL95Z's Avatar
whats the Torsen T-2?
Old May 25, 2003 | 11:40 AM
Larnach's Avatar
It's made by Zexel, worm gear operation, prolly the best differential you can buy if you do a lot of road racing. An Eaton/Auburn/ARB/etc. etc. doesn't really work all that well when your trying to turn in.
Old May 25, 2003 | 12:00 PM
brain's Avatar
Where is the weak point in the 7.5? Is it simply the gears? I would figure you could always get better axles, and a better carrier, so that must be it. Is it simply too small? Gears just too brittle?
Old May 25, 2003 | 12:04 PM
Larnach's Avatar
28 spline axles don't help much, the 8.5" 10 bolts aren't that weak, but they put the 7.65" in ours... besides with the money spent on rebuilding a 10 bolt, your half way to a 12 bolt/9"/8.8".
Old May 25, 2003 | 07:17 PM
LilJayV10's Avatar
So whats the deal with the 8.8? Thats out of a mustang isnt it?
Old May 26, 2003 | 12:22 AM
Larnach's Avatar
Mustang, Bronco, Explorer, F150 etc. etc... much much stronger.
If it can handle 500ft. lbs and 35" tires without a problem, it can handle my power.
Old May 26, 2003 | 12:24 AM
LilJayV10's Avatar
and how much are they selling these rearends for?
Old May 26, 2003 | 12:30 AM
bob94z28's Avatar
From: Council Bluffs, IA Might as well be Omaha though!!!
i've heard that the 8.8 is equivalent to our 12 bolts, and then the 9 inch is just the mack daddy of rearends.
Old May 26, 2003 | 12:35 AM
Larnach's Avatar
I think they are selling them for around $1700 complete, thats about $500 less than complete 12 bolt or 9" with the basics.
I beleive the 9" would be much lighter than the 12 bolt or the 8.8" give the fact that its housing is a stamped peice of metal and the third member can be made of aluminium or cast iron... whereas the 12 bolt or 8.8" is an entire unit in cast iron... however the 9" produces a lot of heat and its pinion shaft height is a bit higher than the 12 bolt or 8.8", not really ideal for road racing, but it is still used in high end road racing series because of its strength and reliability.
Old May 26, 2003 | 01:16 AM
ATMINF's Avatar
I would say that a M/W Dana 60 would be the mack daddy, but it would be very pricey and heavy. A 9.75 compared to a Ford 9 and a Chevy 12 bolts 8.75.
