best way to screw up a TC
Old May 23, 2003 | 10:51 PM
rage366's Avatar
yep...you read correctly.
the reason i asked is because i wanna know if my tc needs to be replaced. the tranny overheated and the clutches were torn apart, and there was debris going through the TC...not to mention the heat.
so, is the tc dead? i'm getting another tranny, so i dont wanna put anything in there that will have debris in it.
oh yeah, both the tranny and the tc had 400 miles on them...the tranny is fried....yes, fried!
--shokoor--
Old May 23, 2003 | 10:57 PM
Larnach's Avatar
M6 swap.
Old May 23, 2003 | 11:03 PM
Larnach's Avatar
Or you can buy mine which is working perfectly (2nd gear chirps, no rev limiter hitting ever) for $550 complete.
Old May 23, 2003 | 11:04 PM
Mizz96Z28's Avatar
If your tranny blew with that TC on it I definately wouldn't use it again whether it was still good or not due to the contaminated fluid. So the TC does need to be replaced.
Old May 23, 2003 | 11:11 PM
yorkie's Avatar
I have a good used torque convertor...
name price, I switched to a 2600 stall.
Old May 23, 2003 | 11:13 PM
rage366's Avatar
yeah, you're right. i've only had the tc for a month, i'm just gonna send it back to JEG'S.
i went ahead, and bought a rebuilt tranny from a pro for $500. well, it was $750 and my old tranny, but he cut $250 off because i told him i'd do some computer work for him.
what would be a good excuse to tell JEG'S to get them to send me another one?
Old May 24, 2003 | 12:30 AM
94FlamdS10Blazr's Avatar
tell them you were having issues and took it to a shop and they said that the coverter blew up and sent stuff into the tranny destroying it. Tell them your not too terribly pissed but want a new converter. You were going to replace/rebuild the tranny soon but this just forced you to do it earlier than expected
Old May 24, 2003 | 12:34 AM
yorkie's Avatar
I had a summit cheapy convertor come apart in a ...
turbo 400, wiped the tranny out, called them and they gave me a rebuild kit at discount and credited me the money for the convertor, then I got a tci.
Old May 24, 2003 | 01:21 AM
rage366's Avatar
yeah, my stall was a 3000 tci streetfighter
Old May 24, 2003 | 01:29 AM
yorkie's Avatar
that was summit...
let us know how jegs does.
Eric
Old May 24, 2003 | 01:30 AM
rage366's Avatar
well, i talked to them a little earlier, and they told me that they'd switch it for me....but i'm not sure if they'd switch it if my tranny's what caused the damage to the stall...even if it's a month old.
Old May 24, 2003 | 08:35 PM
rage366's Avatar
well, i just told jeg's to replace the tc...a friend suggested that i just flush this tc, but i dont really wanna take that chance with a bran-spankin-new tranny. unfortunately, the stall wont get here till thursday!
Old May 24, 2003 | 08:43 PM
FastZinTennessee's Avatar
Best way to screw up a TC........ hmmmm, well take a stock rebuild TC with no furnace brazing or heavy duty bearings, and spray a 150 shot out of the hole on ET streets
John
Old May 24, 2003 | 08:44 PM
rage366's Avatar
John
you speakin from experience?
Old May 24, 2003 | 08:52 PM
Somewhat. I had a buddy sell me a TC that was his buddies. It is a Dacco 2200 lockup stall. As soon as we installed it, when I put it into gear I heard a roaring noise, but when I got moving it went away. It certainly stalled higher than the stock converter did. Felt marginally faster as well. As soon as I got to the track I realized that I had not gained anything, except for what I got from drag radials. Then I learned that the guy who had it before me sprayed it off the line and had pretty much f*cked the converter up. It was only $50, so I'm not pissed. Hell it went 7.80s in the other car it was in
Two morals to this story- do not buy parts that wear used, and also, if you want to spray a big shot off the line, get a heavy duty converter.
John
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Henson071
Aug 4, 2015 09:32 AM
Z28Freak86
Apr 28, 2015 10:35 PM
squarehead
Nov 21, 2014 08:02 PM
