Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
trans-go???
Old Aug 23, 2002 | 11:06 AM
BLU98Z28's Avatar
Post trans-go???
I had my shift kit installed last weekend. I had the guy put it on the 2nd setting and it barely feels like its shifting harder than stock. I also had a Yank 2600 stall put in too. Would that effect the firmness of the shifts. I would not think so since its such a low stall. I'm just a little dissapoited with the shifts. Does anyone else have their shift kit on the 2nd setting? How does it feel?
98 Z A4
STOCK NUMBERS
289.7 HP
312.4 TRQ
13.378 Best Time
Old Aug 23, 2002 | 11:48 AM
91Bird305's Avatar
Post
I have my transgo setup for automatic and it shifts really hard.
1991 Firebird 305
Eric Natzke
"It ain't Stock"
http://members.aol.com/j007golden/91firebird.html
AIM: J007Golden
Old Aug 23, 2002 | 12:54 PM
97f1z28's Avatar
Post
I have mine set with 2 washers. Mine will always bark 2nd and sometimes 3rd.
97 Z28 Convertible
A4, K&N CAI, Flowmaster cat back, TB bypass, MAF descreened, Transgo Shift kit, BM trans cooler, BMR strut tower brace, BMR subframe connectors, 3.73 GM motive gears, TA Girdle, Y2K vette rims, SLP quad in the center exhaust
Waiting For install
BMR Panhard rod, AFPR, Hypercoil springs
http://camaroz28.cardomain.com/id/97f1z28
[This message has been edited by 97f1z28 (edited August 23, 2002).]
Old Aug 23, 2002 | 01:05 PM
Black Sunshine/ 00SS's Avatar
Post
It's because of the convertor, I had the same thing happen, I had that installed when I put in the Vig 3200, and I can barely tell it's there, it doesn't bark.. But then again, maybe that's why my tranny & rear lasted as long as it did. No real performance gain from it anyway, just cool to have. So if it's not enough, take it back & have it bumped up. Good luck.
hchap63@hotmail.com
01/SS, Black A4, TR224/112, ARE stage 2 heads, lid, FTRA, PMAF, PTB, Grott LT, true duals, NGK, ASP pulley, Vig 3200, LCA, poly TAB, Convo pros, ET Streets, 3300 raceweight. Little bit of juice..
Best ET: (All bolt ons) 11.496@116.42 (1.52)
Current best after Head & cam & nitrous:
10.88@124 (1.60)
Motown Muscle King of The Hill winner 6-8-02. Want some? Get some!!
RIP #3 Dirty Dale!!!
Old Aug 23, 2002 | 03:04 PM
Firehawk#69's Avatar
Post
It is definitly because of the converter. With my ST3200 my shifts were fairly slopy, and still slopy after the LS1 edit increase in shift firmness that was done at APE. Don't worry, it won't make you lose any time at the track if you don't bark second.
Marco
Old Aug 23, 2002 | 08:29 PM
BLU98Z28's Avatar
Post
I thought it might be the converter but because it is such a low stall I thought it wouldn't effect it that bad. Oh well I guess I'll just have to bump it up.
Kataklysm
Jan 14, 2005 08:21 PM
Jay-Roll
Parts Wanted
Jun 20, 2004 12:39 AM
"White Knight"
May 21, 2004 09:33 PM
Tobe2wild
Oct 10, 2003 05:57 PM
