Somebody tell me if this is the right A. Fuel Pressure regulator before I buy it.
Old May 12, 2003 | 07:15 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Im took off my fuel injection and went to carb. I know that I need a regulator to take the fuel pressure from 55 of so down to around 7 psi so tell me which one of these is the right one. There are two Mallory ones two port and 3 port. Which one do I need?
Two Port
Three Port
This one is Summit Brand and is substantially cheaper than those. Will this one work?
Will This Work?
Thanks for your help.
Old May 12, 2003 | 07:32 PM
mrr23's Avatar
the 4309 is what you'll need. has the return feed at the bottom of the regulator. i used to sell mallory products. the summit one is basically a holley one. the max input on those types are 15 psi.
Old May 12, 2003 | 07:54 PM
DarthIROC's Avatar
So the Summit one wont work because the TPI pump I have puts out like 50 psi?
Old May 12, 2003 | 08:08 PM
mrr23's Avatar
yes. before buying one, check the input pressure. the 4309 will handle it.
Old May 19, 2003 | 03:46 PM
DarthIROC's Avatar
Need help installing Mallory Fuel Pressure Regulator.
I ment to make a new thread for this please go here if you have any experience with these things
http://web.camaross.com/forums/showt...hreadid=122386
Old May 19, 2003 | 05:33 PM
AutoRoc's Avatar
ihkglgh
I have the 4309 3 Port on my TPI-Carb swapped setup. Works fine. Adjustments work great!
DirtyDaveW
Dec 1, 2016 05:37 PM
Gtpguy
Jan 26, 2015 04:50 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
