how do I set the tps, or just screw it on?
Old May 11, 2003 | 07:49 PM
yorkie's Avatar
I know on the tuned ports you can adjust this? But what about the LT1's??
Old May 11, 2003 | 08:15 PM
turbo_Z's Avatar
i think the computer always resets it to zero when you shut off the car so just bolt it on and go.
Old May 11, 2003 | 09:53 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
You may have to drill out the holes for the tps sensor alittle, that way you canmove it from side to side untill it reads zero. I had to do this when I upgraded my TB to a 58mm. I'm guessing your using auto-tap or somthing else to see where it's it??
Old May 11, 2003 | 10:02 PM
With a stock TB, you don't need to adjust anything. The TPS is not adjustable unless you slot the mounting holes as previously stated.
Old May 11, 2003 | 10:07 PM
yorkie's Avatar
OK so just bolt it on and go.
If it needed to be slotted then the factory would of slotted it I feel.
Old May 11, 2003 | 10:15 PM
Blk94Z28LT1's Avatar
Turbo is right, just bolt it on. When you first turn your ignition on the pcm resets it to zero.
Old May 11, 2003 | 10:16 PM
Re: OK so just bolt it on and go.
Every time you turn the key ON, the pcm reads the voltage with the TPS closed. It then "sets" that as 0% throttle for all calculations during that driving cycle. As long as the initial voltage is between .3 and .9 volts, things are ok.
Old May 11, 2003 | 10:20 PM
yorkie's Avatar
OK thanks for the info
wont slot it.
HectorM52
Jul 30, 2017 11:46 AM
grgguy
17
Feb 23, 2015 07:57 PM
Chris Anderson
Jan 27, 2015 08:30 AM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
