E/t Streets What size rims
Old May 8, 2003 | 05:34 PM
99SuperS's Avatar
I'm intrested in getting a set of Pro stars and E/T streets for my 99 SS. I was just curious what size rims and tires you guys run on your cars.
Width, backspacing, any help would be appreciated for the fronts and the rears. Also I wont be using these on the street very much if at all. Thanks
Old May 8, 2003 | 08:38 PM
95TealLT1's Avatar
For the stock 16 x 8 inch rim you can use “26 x 10.5 x 16”.
I just picked up a couple of salad shooter rims cheep. I plan on putting a set of ET’s on them soon. I'll only be using them at the track. I think they will make about a 0.2 second difference in my 60 ft times. Especially since I’ve had a 3000 stall converter installed since the last time I was at the track.
Good Luck!
Al
P.S. They All so make a "26 x 11.5 x 17" that should fit on the stock 17 inch SS rims.
Old May 8, 2003 | 09:44 PM
ucrazymonkey's Avatar
Here is what I went with from Summit Racing:
Weld Draglight 15 x 8 5 x 4 1/2 x 4 3/4 with 4 1/2" backspacing. $148.95 x 2
Wels Draglight 15 x 3.5 5 x 4 1/2 x 4 3/4 with 1 3/4 backspacing.
$114.95 x 2
Mickey Thompson ET Streets MTT-3053 26 x 10 x 15.
$159.85 x 2
165R15 from PepBoys $29 each
MR Gasket Wheel Spacers for front MRG-2371 5/16" thick $11.95 x 2
Lug nuts from AutoZone $1.28 each with spacer.
You will need to grind your rear brake caliper down a little.
Old May 9, 2003 | 11:35 AM
TNT SS's Avatar
I run:
Rear--Weld Draglites 90 series 15 X10, 7.5 BS
Hoosier Drag Slicks 28 X 10.5
Front--Weld Draglites 90 series 15 X 3.5
Volkswagon all season radials
The rear slicks are about as big as you would want to go, and will require some love taps from a 15# sledge.
Alternate to drag slicks (DOT Slicks)
Mickey Thompson ET Street 28 X 12.5
Hoosier QTP 27 X 11.5 or 28 X 11.5
Hope that helps. Personally I would reccommend the Hoosiers over the MT. More tire/track contact patch.
I just decided to ditch my 26 X 10.0 ET Drags. Too small for 4.10 gear and new transbrake setup
HectorM52
Jul 30, 2017 11:46 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
Jason Short
Jan 19, 2015 06:33 PM
Azimiut
Jul 22, 2002 05:47 PM
