How good are the stock connecting rods?
Old May 3, 2003 | 03:55 PM
BAD97SS's Avatar
I was just wondering. I have couple pistons messed up and was going to get a set of pistons. Just with a little more compression and was wondering if the stock rods can handle it.
Old May 3, 2003 | 04:25 PM
GM rates the PM rods in your 97 at 450HP. Two failures that I have seen, one that is documented on the para-noid website, and another, were both on engines that would appear to have exceded 600flywheel HP. Bumping the compression ratio a little shouldn't put you into the danger zone.
Old May 3, 2003 | 04:59 PM
blownbird01's Avatar
I've seen high 10's with 13#s of boost on stock crank & rods. Guy I know ran that with no problems. With what you are planning on doing, you should have no problems. You never know though!
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
