93 blowing air pump fuse
Old May 3, 2003 | 11:08 AM
t.renz's Avatar
Does this mean the pump has had it? How much does this part cost? Is there a recall on it??
Thanks,
Tim
Old May 3, 2003 | 11:27 AM
SWINGRRR's Avatar
You could have a short somewhere. Not real easy tracing down the wires, due to the wire looms, and tape. Maybe time to yank it off the car!
Old May 3, 2003 | 04:36 PM
Pull the electrical connector off the pump. Put a good fuse in it. That will tell you if you have a problem with the wires. If the fuse doesn't blow, connect the AIR pump and start the car. If the fuse blows, there's a good chance the pump has rusted up and is getting hard to turn. The early models also had a problem with undersized wires, so there is just too much resistance when the AIR pump starts to sieze up.
You might also want to check the black, conical check valves that keep exhaust gas from blowing back into the AIR pump. If these valve start to leak, it will just speed up corrosion of the AIR pump, when the water vapor on the exhaust starts to condense in the pump.
There was a recall for the AIR pumps on the 95 and up models only.... not for us 93 and 94 owners.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
