Went to the track again last night, got no traction and some bad caliper rattle! help
Old Jul 18, 2002 | 09:24 AM
jp2002ls1's Avatar
Post Went to the track again last night, got no traction and some bad caliper rattle! help
I went to the strip again last night, it was 98 degrees and 100% humidity. I was running 13.4's and 13.5's all at 107 or 108 mph. I couldn't get traction if my life depended on it, my 60' times were all 2.38 or higher, and I was the only one at the track that was seriously squaking the tires every time I shifted with my M6 even when I shifted into 4th. I need some advice as to why I am losing traction so bad and why my tires squak at every shift, they didn't do this nearly as bad before I put SLP subframe connectors on, could this have made the difference? Also I need some help, I was trying different air pressures and when I kick my tire hard I notice that the rear callipers rattle, does anyone else have this problem?
Old Jul 21, 2002 | 12:34 PM
Azimiut's Avatar
Post
I had a rattle in my caliper and realised that the little spring like thing that pushes pads back out fell off. could be that. try to move the pads, if they do, there you are.
1994 Green/Grey matalic Camaro Z28 !CAGS-CAI-Ported MAF-AZSM 52mm TB-1LE Elbow-UD Pullies-Ported MAF-HI-6 + LX92 Coil-B&M Ripper-RKSport Headers-SLP Y Pipe-Random Tech Cat-Borla Cat Back-160 Therm-'98 Front Brakes-Eibach Pro Kit W/Blistein
Old Jul 22, 2002 | 04:18 PM
jp2002ls1's Avatar
Post
Thanks for the help, I checked one side and it was fine, now I gotta check the other, it is the rear callipers that seem to rattle.
<font face="Verdana, Arial" size="2">Originally posted by Azimiut:
</font>
CGM2010CAMARO
Apr 7, 2015 07:44 PM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
JoFerZ
Aug 31, 2003 12:49 AM
RichardZ SS
Aug 3, 2002 12:26 PM
