Cheap Mods
Old Apr 26, 2003 | 10:43 AM
Newbie97's Avatar
Cheap Mods
Well what do you guys do for the cheap mods? I already have K&N and Flowmaster installed on car. TB bypass done, LT4 knock module on the way. I know I could get a 1le elbow. My big project next after vaction is hedders and electric water pump with Bryan Heter programming. Is there anything that I could do to better the car any before these installs? I know a little about the Lt1 since I own a hot cammed Impala SS with tons of mods.
I heard there was a mod to firm the tranny by removing the console and pressing a button but need more info before I try that. Thanks for any info Travis
I know this is a debatable ? but what is the best hedder for the Z. I wont long tubes because I love the cars power. I see Jet Hot coat is offering a GP that sound good. Just want opinions to make up my mind.
Old Apr 26, 2003 | 11:01 AM
CamaroGuy22's Avatar
Why dont you get a FIPK instead of just an air filter? Other than that it looks like to me all the cheap mods have been done already... the 1le elbow doenst help much at all, its a waste of money. I think you are on the right track with long tubest though!
Old Apr 26, 2003 | 11:14 AM
ba96ta's Avatar
Normally I would say don't bother with the 1le elbow,but since your going to get the electric h20 pump. I would say go ahead becuase it won't fit with the donkey silencer. Then I would recommend some 1.6rr's. They really woke my car up, and you already have the lt4km
Old Apr 26, 2003 | 12:44 PM
funina91ss's Avatar
I think most people over look tires. either DR or Slicks.. Not really cheap but worth it.
Old Apr 26, 2003 | 12:49 PM
Mtrhds94Z's Avatar
Re: Cheap Mods
If you have a 97 Z [per your handle] you can't, that is only in 94-5 PCM's..
Old Apr 26, 2003 | 01:59 PM
RedWolf's Avatar
Re: Re: Cheap Mods
more info on this would be great..never knew or heard about it
Old Apr 26, 2003 | 02:29 PM
Newbie97's Avatar
I already got the FIPK it came on the car. It looks like Im on the right track then. I guess when I fix the most dreadful think the intake leak(I Im not the only one) I do 1.6rr and springs. I just wanted to get all the bolt on stuff out of the way first. Thanks guys for info
Old Apr 26, 2003 | 03:21 PM
Mtrhds94Z's Avatar
Re: Re: Re: Cheap Mods
It is the firebird 'performance shift mode' mod for 94-5 Z's...
http://web.tampabay.rr.com/jayz28/tranperformance.htm
for a how to..
Old Apr 26, 2003 | 03:30 PM
Re: Re: Re: Re: Cheap Mods
for a how to..
How much benefit does that give you?
Old Apr 26, 2003 | 05:18 PM
RedWolf's Avatar
for a how to..
thanks alot....is it worth the effort or should i just get a Trans-go kit or maybe do both. does it hurt anything...(eg. computer, tranny.etc...?)
Old Apr 27, 2003 | 05:50 AM
Mtrhds94Z's Avatar
http://members.***.net/chipsbyal/page/trans/index.html
Try that link for more info..
It's worth doing for a 94-5 Z
Firmer shifts that 'hold' longer, and it downshifts more aggressively at part throttle, etc..
Old Apr 27, 2003 | 06:16 AM
transamtom's Avatar
First for Newbie 97, descreen the MAF and port it(remove the metal vanes) do not touch the plastic part or the little sensor wires.
The ported MAF was worth .05 at the track,a free half tenth
Second for Redwolf: My car has the performance shift button on the console,I have tried it at the track and I have not noticed a difference one way or the other.
The extra RPM just take you past your peak power,unless your cammed.
Old Apr 27, 2003 | 06:28 AM
brokenz's Avatar
I finally got mine done last week. It won't hurt anything. 94-95 it signals the PCM to go into "performance" mode. Your PCM already has the tables for this programmed in it. It will shift at a higher mph in relation to throttle opening and it will use a different pressure offset table (more line pressure.) Overall pressure at most throttle positions is less than what you would end up with a Hypertech (which I have tried and consider too firm.) The max line pressure that the PCM will allow is not changed in performance mode. As a bonus you can further edit these tables with LT1edit and have two radically different shift programs if you like.
Formula Steve
Sep 19, 2023 08:31 AM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
jackpawt883
Aug 26, 2015 11:22 AM
CARiD
Jul 7, 2015 08:19 AM
