Fuel Injector????
Old Apr 25, 2003 | 10:33 PM
jasons93z's Avatar
Question Fuel Injector????
Do they make noises when they are stuck or going out. I hear a loud tapping (only when i give it good amount of gas) noise that only goes on when it is first started up and it only last about 2 minutes. I know its not anything like the lifters because the noise stops if i let of the gas and let it coast from any rpm's. I am stumped. Im think fuel injectors, but i have no idea. Oh, i also have a loss of power, but its only SOMETIMES.
Old Apr 25, 2003 | 10:35 PM
madwolf's Avatar
Fuel injectors tick all the time. Your problem is probably something else. An exhaust leak maybe?
Old Apr 25, 2003 | 10:49 PM
jasons93z's Avatar
but why would it only happen when the engine is just started up.
Old Apr 25, 2003 | 11:09 PM
jasons93z's Avatar
cmon, someone has got to know
Old Apr 25, 2003 | 11:14 PM
IrocManiac's Avatar
Could be an exhaust leak as the engine is just started, it's "cold" and there is sometimes gaps off one of the manifolds as the engine warms up the seals will do a better job sealing due to thermal expansion...
Old Apr 25, 2003 | 11:38 PM
jasons93z's Avatar
what would explain the power loss? And remember, it only does it when i apply good amount of gas, when i let it coast the noise goes away. If it was an exhaust leak then the noise would be there all the time til it heated up.
Old Apr 26, 2003 | 08:48 AM
jasons93z's Avatar
ttt
Old Apr 26, 2003 | 09:02 AM
An exhaust leak will always be more detectable under load. An exhaust leak will throw off your O2 readings. Try looking for it when you first start your car, when you can hear it the most.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
