Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Too rich and then now too lean
Old Apr 25, 2003 | 06:01 PM
ltlhomer's Avatar
I loaded the stock program back in there and now it's backfiring a lot and seems to be running lean while before it was fouling plugs like crazy. The idle is definitly too low but I can fix that myself. Does anyone have any basic tunercat programming skills that might be willing to help me get this thing running long enough to drive it to the exhaust shop and back? If anyone can do this, give me a call at 586 294 2321 or email me at LTLHOMER@aol.com Thanks guys, Sean
Old Apr 26, 2003 | 11:56 AM
WeTDrEaM's Avatar
Sean,
You need to start with putting thre programing in the car the guy supplied you with. Then you need to pick up the FPR that I ordered you and adjust that first.
Old Apr 26, 2003 | 04:04 PM
ltlhomer's Avatar
Well for part of my grad gift my parents said they'd pay for dynotuning so now that it's free I'm prolly going to go that route. Speedworks said the computer would cut injector pulse widths or something fancy like that and negate any gains from the adj. fpr. I just want something that'll get me to Doug's and get me to speedworks cuz towing it will be very expensive.
Old Apr 26, 2003 | 07:44 PM
WeTDrEaM's Avatar
So did you end up picking up the FPR that i ordered for you?
Old Apr 26, 2003 | 07:50 PM
Rodrigues's Avatar
lthomer, a temporary "bandaid" would be to adjust your injector rate to trick the pcm into believing its giving a certain amount of fuel when its not. PCM4Less will do this in their tunes as well. If you are running too lean you will want to lower your injector rate to make the pcm try to open the injector more to give it a certain amount of fuel, in return giving it more fuel.
Old Apr 26, 2003 | 10:40 PM
ltlhomer's Avatar
Danee...I called up there the day I was supposed to get it to make sure it'd be allright if I didnt' get it and they said it was all taken care of so it's cool.
And I saw ya cruising on Friday Danee. Car looked very nice man!
Thanks Rodrigues...I just wish I had a clue what I was doing with all this stuff.
PopoFormula
Oct 12, 2015 04:19 PM
drt
Sep 27, 2015 04:39 PM
HAWG
Sep 25, 2015 11:41 AM
marlar98
Sep 19, 2015 07:53 AM
