How is the SLP 2400 Stall converter?
Old Apr 23, 2003 | 11:25 PM
BlackLT1_TX's Avatar
I have a 95 T/A, thinking of this converter and a tranny cooler.
I found it for 295 new, and figure it wont beat up my stock 4l60e as hard as a 3200 or up.
How much am I looking at dropping e/t wise (running a 13.9 with 2.1 60').
Thanks,
James
Also, should I do a shift kit at this time (would it net me anything).
Old Apr 23, 2003 | 11:40 PM
ucrazymonkey's Avatar
Too small. Why even do it, if your not REALLY going to put one in. 1800 RPM is stock. You need to step up to a 2800 stall. My TCI Converter from Summit Racing was $429 shipped. It is a 10" COnveter on a 1.75 STR. It dropped my times by a strong .5 in the quarter. Make sure you get a cooler. Summit also has one fro about $30.
10" StreetFighter Converter
Old Apr 24, 2003 | 12:39 AM
chesee48's Avatar
I agree, i would say that a 2800 is the lowest i'd start off with...
Get a 2400, and you'll be wanting a 2800
Old Apr 24, 2003 | 07:50 AM
Dale 94 TA GT's Avatar
SLP converter
I have this converter and it does what it is intended to do. Before my hot cam i could cut 1.82 60's, afterwards the best i could do was a 1.92, I then put the SLP converter in and go 1.72-1.75. I actually hate the way a stall feels during normal driving, feels real sluggish unless you are getting on it. If I had to do it over again I would put my stock stall back in, but just my opinion though and every one has one. Hope this helps
Old Apr 24, 2003 | 08:10 AM
ChuckZ28's Avatar
definately too small. I wouldnt go smaller than 3000. I got a 3200 and with the cam I have its too small now. I recommend COAN. they make excellent covertors that work just as well as the vigilante but still retain a good punch when you hit the gas. Its a very tight convertor. I would say between 2800 and 3000 for you.
Old Apr 24, 2003 | 08:49 AM
94SLUG's Avatar
Way to small why not go with 2800+. Get a good one, spend the money.
thenewkid
Apr 12, 2015 07:42 PM
marine1bird
10
Jan 25, 2015 12:02 AM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
mysticslp2002
Jul 29, 2002 02:03 PM
