15x10??
Old Apr 22, 2003 | 04:31 PM
lt1camaroman93's Avatar
15x10??
I know you should use a 7.5 inch BS.. is there any way to get away with a 6.75 in BS.. casue i can get a set for a good price, but i don't want to if i can't get them to fit.
Old Apr 22, 2003 | 04:41 PM
Might be possible.... depends on how much you want them to stick out. They will be moved about 3/4" further out from under the fender than these:
15x10, 7.5BS
Another shot
Old Apr 22, 2003 | 05:30 PM
grendal's Avatar
IMO it won't look very good and it will stick out too much. Actually, sticking out AT ALL is too much for my taste.
-Michael
Old Apr 22, 2003 | 06:18 PM
i'm not that worried about the looks cause its for the track.. i just wanted to make sure they won't stick out to the point where a 27.5x12x15 or 27.5/11.5x15 wont hit the quarter panel.
Old Apr 22, 2003 | 08:03 PM
1FASASZ's Avatar
15x10, 7.5BS
Another shot
what size slick do you run? did you have any clearance problems, or did you just bolt them on and go?
Old Apr 22, 2003 | 11:45 PM
That's a Hoosier QTP 28x11.5-15. They fit with no problems, until trap speeds went over 125MPH... then they started growing enough that they were hitting the front (sheetmetal) edge of the wheel opening. I ended up moving the axle assembly back about 1/4", and let the tires start to "radius" the front edge of the rubber bumper cover instead. With a 27" tire you shouldn't have any problems at all.
Clearance
I just switched to M/T ET Drags, in a 28x10.5-15W, and I had to cut at least 1/2" off the edge of the bumper cover to even fit them in the wheel openings. The M/T's are listed as 28.1", but they seemed larger than that.
sideways_Into_3rd
Feb 15, 2004 03:33 PM
BeaversTA
West South Central
9
Jan 18, 2004 09:56 PM
extreme79z
Classic Engine Tech
Dec 7, 2003 06:17 PM
chevyguy3
Aug 18, 2003 10:37 PM
chevyguy3
Jun 18, 2003 01:18 PM
