broke alternator bracket!!!!!
Old Apr 20, 2003 | 01:17 AM
1995redZ28's Avatar
Angry broke alternator bracket!!!!!
just finishing up my hotcam install and im almost done puting everything back together. well i go to put the alternator back in.... i set it in place put in the small bolts to hold it, then i went to put the long bolt in at the top. i was tightening and everything seemed fine.... then it stripped!!!!! and the bracket around the bolt cracked and fell off!!! the alternator seems pretty sturdy without it but what should i do with it??? replacing the whole bracket looks like way to much work. any ideas?!
.... oh and this def. wont stop me from starting my car after 4 longs days of the cam install.... cant wait!!
Old Apr 20, 2003 | 08:01 AM
Heli-coil the hole and have the piece welded back on. There is a lot of tension on that top bolt. If you don't fix it, you will probably end up with a broken alternator housing.
Old Apr 21, 2003 | 10:15 AM
1995redZ28's Avatar
yeah i guess that is really my only option! what is the bracket made out of? would i be able to use something like JB weld in order to keep it together?? only problem is that is cracked into 2 pieces around the bolt hole, and i can only find 1 of the pieces hopefully the other piece drops down once i move the car! so do you guys think JB weld will hold up? i appreciate the help!
Old Apr 21, 2003 | 11:20 AM
The bracket is aluminum. A competent welder could fill in where you have metal missing and then you could re-do the bolt hole if needed.
Old Apr 21, 2003 | 11:52 AM
Fastbird93's Avatar
Same thing happened to me a couple years ago. I ran the car like that for almost a year without a problem. Check on Ebay or maybe call Billy Grahams salvage yard. I got a new bracked for $20 bucks off of Ebay. Swapping it out is a pain because you have to take the power steering pump off and the AC compressor, but it's worth the time.
Old Apr 21, 2003 | 11:59 AM
burnemonm1's Avatar
I wouldn't do the JB-weld I'd have it welded. replacing it would be a task but if you could get one for 20 I'd do it.
Old Apr 25, 2003 | 08:21 PM
ram air camaro's Avatar
sh*t same thing happened here a year ago and till a couple of hours ago my bracket broke again but this time at both places where the alternator hooks up. i looking to replacing it.
Old Apr 25, 2003 | 09:43 PM
1995redZ28's Avatar
yeah it def. sucks!! im just going to have mine welded back together and tap a new hole in it. looks like too much trouble to replace! and after doing the cam install, i need a break from working on the car for a while! i just want to get the thing started!!!
Old Apr 26, 2003 | 12:30 PM
i would like to do that but mine broke from the top alternator mount and the lower alt mount, they sell them www.gmpartsdirect.com for only $38.00 i'm going that route. good luck
Devinfoote87
Feb 12, 2016 03:21 PM
Thirim
Jul 30, 2015 01:29 PM
Boss002
Jul 24, 2015 10:47 AM
94Form
Jul 17, 2015 10:56 PM
