How happy are you with your NGK Plugs?
Old Apr 19, 2003 | 09:47 PM
firebirdslickg's Avatar
I'm planning to purchase NGK's for my next tuneup (With Accel 9000 Spirals) Anyone who has used NGK TR55's, have you been happy with them? I had Delco Plats put in 2 yrs ago, and the car didn't run as great as I wanted it to. What kind of life are you squeezing out of the NGK's too while I'm at it
Thanks!
Old Apr 19, 2003 | 10:57 PM
Does that mean nobody is happy with them?
Old Apr 19, 2003 | 11:03 PM
snakeatinZ's Avatar
Thumbs down
do your self a favor and go back to ac delcos, my Z ran like crap with tr55. HORRIBLE IDLE! he11, they are made in Japan for god sake.
Old Apr 19, 2003 | 11:12 PM
Buttercup's Avatar
I haven't had any problems with my NGK's. The regular AC Delco platinums are horrible. It's fairly common to have the platinum "pucks" come off the electrode, embedding themselves into valveseats and opening up the gap.
I often change my plugs whenever I have the old ones out... so almost as much as I change my underwear If you aren't running platinum I'd probably change them at most 30k miles. If you're running nitrous, boost, etc. then I would be inspecting and replacing at shorter intervals then that. If you want to install the plugs and forget about them then platinum is the way to go... although I still wouldn't let them go 100k miles.
Old Apr 19, 2003 | 11:20 PM
Blk94Z28LT1's Avatar
no problems with my NGK's
Old Apr 19, 2003 | 11:35 PM
Vader's Avatar
I like the TR55's, although I only get about 8000 miles out of them. I need a new set right now.
Delco copper plugs are good too I hear.
I no longer use any platinum plug, as I prefer to pull the plugs yearly and inspect the cylinder by cylinder combustion colour.
Old Apr 20, 2003 | 12:21 AM
Every 8000 Miles? Do they start missing or something around 8000 or do you just change them? LT1 spark plugs are a pain to begin with. But I'm telling you, my delco's are brutal (second pair)
Old Apr 20, 2003 | 12:28 AM
Vader's Avatar
The electrodes round over, which is a sign they need replacing. I can have the y-pipe out of my car in about ten minutes, so a plug change isn't a big deal. No symptoms of worn plugs, just a yearly thing I do. These ignition systems can fire just about anything.
Old Apr 20, 2003 | 04:10 AM
Don 97 SS's Avatar
I recently installed a set of NGK TR5s. The car runs fine. I don't know how long they will last, but I was tired of the oem Delcos loosing pucks and leaving .075" gaps.
Old Apr 20, 2003 | 12:22 PM
$hawn's Avatar
I'd like the ngk's better if those metal plug wire end terminals didnt unscrew. If you like using the ac delcos but not platinums, you can use I use them the R44LTS's.
Old Apr 20, 2003 | 12:35 PM
eagleknight97's Avatar
does anyone on here use splitfire plugs and if so, how are they. Thanks in advance
Old Apr 20, 2003 | 01:05 PM
1BadBrd's Avatar
Well i just put my enigine back together and added NGK and i'm not too happy. But i don't know if it is the plugs wire or opti, so..... But I will find out about the plugs and wire this week.
Old Apr 21, 2003 | 06:44 AM
Thanks for the reply guys, I guess it can't hurt to try the NGK's and see
Old Apr 21, 2003 | 07:30 AM
Fastbird93's Avatar
I Love the TR55's. My car idles rock solid @ 850 rpms, no stutter or anything.
BLK1997Z28
May 7, 2015 03:01 PM
Jazsun
Dec 29, 2014 12:14 PM
Duke
Jul 31, 2002 04:27 PM
