gmmg
Old Apr 20, 2003 | 11:22 PM
zuluman13's Avatar
gmmg
Is there anywhere else i can get gmmg exhaust a little bit cheaper than directly through them.
Old Apr 20, 2003 | 11:54 PM
Dr.Mudge's Avatar
Unless there is a GP they are the only people making it, buy a chambered muffler and rig up your own system and its alot less expensive.
Old Apr 21, 2003 | 06:02 AM
Thebeast431's Avatar
Check the for sale section, but good luck finding someone who wants to get rid of it. You may get lucky, and someone wants to put there car back to stock.
Travis
Old Apr 21, 2003 | 06:27 AM
sleeperZ96BT's Avatar
there are GP's over on the f-body hideout, or at least there used to be. that whole areas kinda a mess right now to say the least. other than that board theres nowhere else that you can post GP's on it because no vendor carries it.
Brian
Old Apr 21, 2003 | 06:39 AM
Mikey97Z's Avatar
You can get the chambered sections real cheap and then have a shop put it all together and make you a nice custom exhaust with a cutout and everything for half the price of the GMMG.
Old Apr 21, 2003 | 06:45 AM
the chambers available to make a home-made GMMG are different then the GMMG ones. ive heard the stainless works and sweet thunder setups, they arent quite as deep and have a minor amount of rasp up top, which the GMMG doesnt have. the cost from what ive seen for 2 chambers shipped and the muffler shop work all said and done is in the $350-450 range, depending on who you have do it and what size/type pipe you use. also the GMMG is stainless and some of these home made ones are not, so theres a price difference there. some of these systems turn out looking alright (i saw one that looked good), and some look like hell. i havent seen one that looks as sweet as the GMMG setup though.
Brian
Old Apr 21, 2003 | 07:43 AM
zuluman13's Avatar
Ok thanks Id rather spend more money and have the exact one I want and have it work good.
Nickster 7
Aug 27, 2015 10:12 PM
BLK1997Z28
May 7, 2015 03:01 PM
Cobraeater
West South Central
Apr 6, 2003 02:51 PM
Mystery Z28
Oct 20, 2002 11:35 AM
sleeperZ96BT
Sep 4, 2002 08:26 PM
