grinding 2nd ...........what's the deal
Old Apr 18, 2003 | 04:55 PM
95z guy's Avatar
Here's the situation. As of 2 days ago, my car started grinding when going into 2nd. It only happened every once in a while and only from the 1st to 2nd upshift. Yesterday, the grinding became more frequent and also started to grind during downshifts into 2nd. Today, it grinds either which way when going into 2nd. However, it doesn't do it if I shift at low rpms such as 2000 or below, but the higher the rpm, the worse the grinding is. The clutch pedal is definitely pushed all the way to the floor during this, and it only happens upshifting and downshifting into 2nd. I asked a buddy who had a similar prob with his car, and it was his throwout bearing. But thats a tremec in a mustang, not a t56 in a z. I don't know much about these things so any help would be appreciated. The car is a 95z m6(obviously) with 101,000 miles and is all original. Please help, I don't want to blow up my tranny.
Jamie
Old Apr 18, 2003 | 05:28 PM
Donny O's Avatar
sounds like time for a 2nd gear syncro....2nd geat take more abuse than any other gear so that is the one that usualy goes first!! not what you wnat to hear but time to rebuild that baby!!!
Old Apr 18, 2003 | 08:19 PM
95z guy's Avatar
any more opinions?
Old Apr 18, 2003 | 10:02 PM
lasingeblanc's Avatar
had the same exact problem... it was the syncros, and i had to have 1st and second gear assemblies completely rebuilt sorry to hear it, man, best of luck
Old Apr 18, 2003 | 10:03 PM
kjlvilla's Avatar
Synchro and speed gear. The synchro equalizes the speed gear to engine speed to allow the hub to engage. The reason it isn't as bad at lower engine speeds is because the speed gear isn't going as fast and is easier to synchronize.
Old Apr 19, 2003 | 01:18 AM
95z guy's Avatar
do i now need a rebuld? and if so , what's the average cost? Thanks for all the help guys
Old Apr 19, 2003 | 03:48 AM
unTAmedLS1's Avatar
If you dont have the money right now to fix i just double clutch when you downshift to second. This makes synchros last alot longer
Old Apr 19, 2003 | 05:52 AM
badass383's Avatar
They are right, 2nd gear syncro. comes from slamming 2nd.
Don't forget you have some type of metal particles (usually bronze or brass) floating around in the gear case now.
Old Apr 19, 2003 | 08:49 AM
yep, you're going to eventually need to rebuild it... it's not gonna go away hehe... i was reduced to skipping 2nd altogether (double clutching didn't do a thing for my 1st-2nd shift) it won't be too bad... if you have the capability of dropping the tranny yourself, and take it to a transmission guy, it couldn't be more than 2-300 bucks to open it and redo the syncros... he'll probably (if he's decent enough) let you SEE what's going on in there and show you the gear assemblies, etc. and let you decide if you want to just redo 1st and second gear (mine were ground out really bad hehe) or if you just want to drop the car off and let him do it all, i'd take a shot in the dark of 6-700 bucks... and you might as well do the rear main seal while that transmission is off, and if you have money, look into the flywheel and clutch assemblies
Old Apr 19, 2003 | 09:14 AM
Rodrigues's Avatar
I believe 1st and second use the same syncro, dont they? Your not actually grinding the gear if it makes you feel any better, your just grinding the syncro. Like they mentioned, you can double clutch and try to "rev match" the gear.
Old Apr 19, 2003 | 09:21 AM
unTAmedLS1's Avatar
You won't believe this but when I lived in Cali for 6 months I was having this happened when I moved back to chicago it actually went away and has never come back. It seriously felt exactly like a synhro too thats the weird part.
Old Apr 19, 2003 | 04:01 PM
95z guy's Avatar
thanks for all the help guys. i guess i have no other choice but to bite the bullet and get the snycros replaced. should i just buy a rebult unit instead? would it be more cost effective?
Old Apr 19, 2003 | 05:24 PM
uuhhhmmm... depends... once a transmission guy cracks it open, he'll be able to tell you... the higher gears in these cars don't become worn basically at all, it's the first 2 or 3 that take abuse... so once he/you get a look at how it all looks inside, you can pass judgement... as far as the syncros, get all of them done, they're usually sold it sets for the tranny, so it'll come with all of the syncros for the whole transmission anyway... i just had 1st and 2nd rebuilt, new magnets placed in, and the fluid changed, 3rd gear through 6th were in pristine condition, so i didn't have to spend $ on them
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
JJOHNROE
Parts Wanted
Oct 23, 2015 02:03 PM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
