werid ?
Old Apr 18, 2003 | 02:10 PM
blackz151's Avatar
werid ?
Can i take my gague cluster out and still have the car right. Like say i wanna make a custom automeater cluster
Old Apr 18, 2003 | 02:12 PM
SloMofo's Avatar
Cool
I'm sure it's doable if you have the time and money. Try the appearance section.
Old Apr 18, 2003 | 02:20 PM
Most of the gauges are wired directly to sensors and not through the PCM, so there is no problem.. this includes oil pressure, fuel level, volts and coolant temp. The tach comes off the PCM, but it is feasible to connect another type of tach that runs off the coil. The speedo is the challange.... the only signal source is the PCM, or direct from the VSS (leaving the feed to the PCM in place also) so you need an electronic speedo, not an aftermarket mechanical unit. And you need an interface box to take the signal from your VSS sensor and translate it to the signal required by the aftermarket electronic speedo. Dakota Digital makes these interface boxes.
You will also have to incorporate the infamous SES light... if the PCM sees it is not connected.... it will set a code.... .
sickler
Jul 25, 2010 07:05 AM
sickler
Middle Atlantic
Jul 13, 2010 05:46 PM
hey01
Jun 22, 2008 04:08 PM
hey01
Jun 29, 2006 08:04 PM
