car crapped up on dyno....need help
Old Apr 17, 2003 | 10:20 PM
smokindastangs's Avatar
tonight i went to get my car dyno'd after the 305 install. I was trying to get the a/f ratio so i could send it to Bryan @ pcmforless. so i get it on there and it runs alright until i get it into forth and have to stomp on it. It hesitated and jumped a lil...then it just stopped pulling; almost like you had turned the key off. The guy suspected that the fuel filterwas wrong so he hooked up something that checked the fuel pressure; but then he found out that it was ok. He thinks that my roller rockers are too loose b/c they are makin some noise; but i don't think that would cause this to happen. It normally idles a little funny. I believe that it is runing lean. It hickups every once in a while. The check engine light comes on for a little while; however, even when it is on, it won't send any codes. ( odb1) so anyone have any ideas?
Old Apr 17, 2003 | 11:27 PM
Showme's Avatar
Man, I wish I was an expert on LT1s. I don't know what to tell you, But there has to be Somebody out there who can get you started in the right direction.
I hope you find out whats going on.
Tim
Old Apr 18, 2003 | 12:14 PM
thanks man, me too! Jason
Old Apr 18, 2003 | 12:18 PM
Rodrigues's Avatar
It obviously sounds ignition related. I would first check if your coil is getting voltage, as well as your ignition control module.
Old Apr 18, 2003 | 07:58 PM
why do you think that it could be ignition related? That doesn't make sence to me b/c it starts up fine; however, it starts running funky after that. However, it looks as if some wires that are grounded w/ the coil need to be re-done, so i am going to fix them. I don't think that it is causing this problem. It sounds like a PCM problem to me.
Old Apr 19, 2003 | 12:25 AM
Kreinmc's Avatar
I almost gaurantee its not the pcm. Don't go and replace unless you are absolutely sure. You can swap one with a buddy to see though if you want, but i'm sure it won't fix your problem. Might be your opti. Does the car still idle fine?
Old Apr 19, 2003 | 12:36 AM
I tighened a ground wire and the car hasn't acted up sence. One question i have though is that could this account for a total lack of power on the dyno...if not i don't wanna go pay for another dyno session and see that it wasn't the problem. Jason
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
JAFO1994
Aug 22, 2002 06:09 PM
