Solid roller too aggresive for stock PCM and stock bottom end?
Old Apr 17, 2003 | 05:10 AM
Rob94hawk's Avatar
I have 60k miles on my hawk and I was considering a solid roller cam setup. But I was wondering if it is overkill since some of the CC extreme cams put out some really good numbers with a stock bottom end and decently ported heads.
The PCM for OBDI only allows for a max of 7000 rpms right?
Give me some feedback please!
Thanx, Rob.
Old Apr 17, 2003 | 08:45 AM
Dr.Mudge's Avatar
You would not want to hit over 7k on a 2 bolt main setup anyway, but yes that is the limitation. Vulva ran a solid on a stock head/bottom 93, ~400RWHP.
Old Apr 17, 2003 | 08:54 AM
kmook's Avatar
Advanced Tech Moderator
I ran a 242/248 585/586 112 solid roller stock pcm/stock bottom end.
It really just depends on your goals what you should run. Like you said a XE will get you nice power.
95chwagon
Jan 13, 2015 09:19 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
Catmaigne
Dec 25, 2014 12:16 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
