Any affordable widebands available?
Old Apr 15, 2003 | 05:14 PM
Highlander's Avatar
Are there any affordable widebands available and any kit that could be installed on the car to tune the car on the road with a wideband???
Old Apr 15, 2003 | 05:26 PM
Mindgame's Avatar
One place I know of is TechEdge.
http://www.techedge.com.au/vehicle/wbo2/kitwb.htm
You can buy one from them or you can buy a kit and build one.
-Mindgame
Old Apr 15, 2003 | 06:30 PM
Highlander's Avatar
HAs anyone used it?? How can you log?? O2 expectancy???
Is there any type of converter so the signal can be fed to the PCM???/
It would be useful if the PCM could log it via something and you can see it on datamaster or something..
Old Apr 15, 2003 | 08:47 PM
merim123's Avatar
Search the lt1-edit forums, there are guys there that are running this...
Old Apr 15, 2003 | 09:39 PM
kingslam's Avatar
usually
You just use it to tune your engine, you get a stand alone monitor, and log your runs then after tuning you remove the wideband o2 as they have a very short life, lucky to get 10k miles on one and they are expensive. A good dyno shop uses them for tuning, then removes them.
kingslam
Old Apr 15, 2003 | 10:28 PM
Highlander's Avatar
I do not plan on using them all the time.. All I want to know is how do you log with them... logging by time is USELESS!!! You need to log by rpm!!!!
RUENUF
Mar 13, 2016 03:37 PM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
Henson071
Aug 4, 2015 09:32 AM
CARiD
Jul 7, 2015 08:19 AM
1996LT1Z28
Dec 4, 2014 09:20 PM
