Pacific Alaska, California, Hawaii, Oregon and Washington
anyone have a spare LT1 fuel rail ?
Old Apr 13, 2003 | 11:22 PM
sideways_Into_3rd's Avatar
or have theirs apart for whatever reason !?
my fuel pressure reads 41 at idle and 43 at wot .. that aint right
i wanna try another regulator (just hook up the pressure sendor and fuel lines .. not install the whole thing) and see if its my regulator thats bad
thanx
ps. or even better, if u have a spare fuel pressure regulator .. that would be best .. thanx
Old Apr 14, 2003 | 12:12 AM
BPS's Avatar
BPS
Why isn't that right?
Old Apr 14, 2003 | 12:17 AM
97TA-WS6-Con's Avatar
I have an extra one, but I agree with Bill, what is the probelm?
Old Apr 14, 2003 | 12:35 AM
pressure is off
shaun u mind if i grab that one off of u and try it otu ?
stock pressure should be in the mid 30s at idle and mid 40s at wot
Old Apr 14, 2003 | 12:40 AM
BPS's Avatar
BPS
Something Injuneer posted a whie back
"Turn the key on, don't start the engine: 43.5psi, +/-2.5psi, so 41-46psi is OK
Start the engine, pull the vacuum line off the FPR: 41-46psi
Engine running, replace vacuum line: 35-38psi (can be higher if you live at a high elevation, or if you have a radical cam with little vacuum at idle.)
WOT: Pressure should return to the "no-vacuum" value, and stay there.
As you drive: Pressure will fluctuate between the values with the vacuum line off and on, depending on throttle movement (vacuum)"
Given that your running a bigger cam your numbers sound fine to me - but i guess testing doesn't hurt.
Old Apr 14, 2003 | 12:43 AM
i'll test my own FPR tomorrow .. i hear if it doesnt hold vaccum its bad .. if thats the case i'll grab shauns ..
but the fact that i have a cam will influence my idle vaccum and fuel pressure ur correct
Old Apr 14, 2003 | 11:29 AM
JD30thZ28's Avatar
I have a regulator if you need it
HectorM52
Jul 30, 2017 11:46 AM
birdblack
Dec 30, 2014 06:59 PM
hotrodyou1
Dec 20, 2014 10:05 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
