"Check Coolant" light, but coolant level is fine??? (3 problems inside)
Old Apr 13, 2003 | 11:03 PM
BlackLT1_TX's Avatar
Today I got this light in my 95 T/A, but the coolant level was fine.
With that said, since I have bought the car it has smelled like the heater core might be leaking, but have seen no signs of this. Is this common, and how hard is it to replace (or bypass).
Also, my T/A seems to run kinda warm, it stays at 180* on the hwy, but sitting for a extended period (at the track staging) it will go a little past 210, and it wasnt even that hot outside. I know you can wire up a switch to the fan, but should it not be running this hot?
So if you can help me with any of those 3 problems, please help!
Thanks,
James
Old Apr 13, 2003 | 11:27 PM
mike95z28
Guest
Posts: n/a
Re: "Check Coolant" light, but coolant level is fine??? (3 problems inside)
There's a sensor right below the radiator cap that senses the coolant level. It might need to be cleaned. This has happened to other members on the board.
If the heat core were leaking bad enough the passenger side would have a good sized puddle of coolant.
Thanks,
James
This is normal for a stock LT1. It is designed to run hot. Hot as in the ranges you're noticing. A quick way to cool the engine down is by using a 160* thermo and programmed fans to start cooling much quicker.
Old Apr 13, 2003 | 11:50 PM
i cant find that sensor, where exactly is it?
I pulled the cap, and there are 2 lines going to it, but neither are sensors.
How far down the radiator is the sensor?
Old Apr 14, 2003 | 12:32 AM
mike95z28
Guest
Posts: n/a
Only a few inches down. These pics should help.
http://csce.uark.edu/~jgbertr/rb/low_coolant.jpg
http://csce.uark.edu/~jgbertr/rb/low_coolant2.jpg
Old Apr 14, 2003 | 12:37 AM
Lt1t56's Avatar
The low coolant level sensor snaps into the radiator tank on the passenger side of the vehicle, about 4 inches down from the cap, dont need to remove cap to see it, it attaches on the outside. You live in Texas ? just wondering I live in Texas.
Old Apr 14, 2003 | 01:16 AM
ya, right south of Dallas, you know anywhere to get cheap lt1 parts around here?
Old Apr 14, 2003 | 01:21 AM
Lt1t56's Avatar
I live near the DFW airport, used to have connections at McDavid and at Freeman, but not anymore, cheapest parts I find now are online.
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
ro2207
Dec 4, 2014 06:18 PM
danielbmx
Aug 27, 2002 11:11 PM
