Car cutting out under heavy acceleration...
Old Apr 13, 2003 | 09:06 AM
nickw_95z28's Avatar
The other day while driving my car I tried to get out in front of some traffic on the interstate and the car started cutting out. It was almost like I was hitting the rev limiter but I was only at 3Kish rpm's. I drove around a while longer to try to get it to do it again. It seems that it only does it when the engine has been running for a long time. I have had some suggestions that it could be my wires are starting to go bad since they are stock and also that maybe my coil is going bad. It's hard for me to tell what could be the problem since its so sporatic(sp?). It doesnt do it consistently...just enough to irritate me.
Old Apr 13, 2003 | 09:54 AM
BigEvil's Avatar
I've had mine hiccup like that twice in six months. There are a few guys around here that'll give a good educated guess. Until you break it though, that's all it'll be.
Old Apr 13, 2003 | 01:29 PM
cals400ex's Avatar
yeah, this will just be an educated guess. i would change the plugs and wires. high rpm misses many times have to do with the coil. also, the opti is a common failure. i would save the opti for last because it is the most expensive. good luck
cmdeshon
Dec 12, 2014 10:51 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
