Anyone have LT1 edit?
Old Apr 9, 2003 | 11:33 PM
whitetrashT/A's Avatar
Unhappy Anyone have LT1 edit?
I'm in the process of putting an OBDI motor into an OBDII car and recently learned that I'll have to delete the crank position sensor via LT1 edit. If I understood right.
I'll buy you some beer or something.
Old Apr 10, 2003 | 02:00 AM
59apache's Avatar
i think that is vin locked so you might have a problem there, but i could be wrong
Old Apr 10, 2003 | 06:22 AM
AHARTZ28's Avatar
they are locked to the PCM, if you are going just to OBD1 then you wont have to delete it, just get the OBD1 PCM swap them and swap the knock sensor to an OBD1 KS as well. the OBD1 PCM will delete it since it wont look for it
Old Apr 10, 2003 | 12:17 PM
Sweet, now anyone know where I can pick one up for cheap?
And will I at least be able to run the car without that plugged in while I still have obdII?
Old Apr 10, 2003 | 12:49 PM
AHARTZ28's Avatar
are you getting an OBD1 block? if so then it may run with the light on but if it does not very good nathan knows where to get a PCM for like $60 i believe.
Old Apr 10, 2003 | 09:24 PM
eddiezlt1's Avatar
$60 for a pcm tell me where
and kc i have lt1 edit so no worries
also no need for KS i will blue wire the pcm for u
Eddie
Old Apr 10, 2003 | 09:45 PM
I busted the crap out of the KS on the removal of the old motor, might need to get a new one anyway. So should I get the obdI or II KS? Or just the cheapest one?
And how can I get in touch with Nathan?
Old Apr 10, 2003 | 10:08 PM
gun4hire's Avatar
KC,
I did this swap back when I have my '96 LT1 Caprice, and it was pretty straighforward. You can leave the CPS plugged in, the OBD1 pcm won't be looking for it.
Eddie's right about the blue wire. I still may have the pinout chart in my PC somewhere if ya need it. I'm sure its out on the internet too... I did swap out the KS in the block too, just to be safe.
I could probably find a pcm for cheap, but I dont wanna give away all my secrets! E-mail me if you can't find something..
Old Apr 10, 2003 | 11:25 PM
Actually the motor I'm putting in doesn't have the CPS, so if i run it while I still have my OBDII PCM in the car, I don't think it would like it.
But I've probably got a month or so before I will be all finished so that should give me some time to save up some cash for that OBDI (and get my throttle body back from eddies apartment)
Old Apr 11, 2003 | 09:14 AM
ford's Avatar
Or you could be like me and run around without a KS for a week or more
Old Apr 11, 2003 | 04:07 PM
gun4hire's Avatar
Guess I should have read the original post closer.
Old Apr 11, 2003 | 10:44 PM
ucrazymonkey's Avatar
If you still need one, I will call and check on Monday if they have any left. just let me know if one is still needed.
It will either be for a F,B,D Body. Either way it will work.
Old Apr 12, 2003 | 01:06 PM
If you could do that I'd really appreciate it.
Maybe it'll be running again by 2004.
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
Bando
Aug 2, 2002 02:18 PM
