Serpentine belt with UD pulleys??
Old Apr 3, 2003 | 12:12 PM
94_Camaro_LT-1's Avatar
Red face Serpentine belt with UD pulleys??
OK, I have the MBA underdrive pulley and alt. overdrive pulley with the 59" 6-rib belt and I noticed that it flaps a lot at idle. Also when Im turnin, it's very rigid and doesn't want to, I dont need this problem to cause an accident...I'll go back to the stock pulleys if need be Anyone have a solution, I don't know of any 6-rib belts smaller then 59"
Old Apr 5, 2003 | 11:23 AM
TTT please anyone?
Old Apr 5, 2003 | 12:29 PM
Sounds like the tensioner pulley isn't in the right positon, probably from too long a belt. If you look at the tensioner pulley, you will see that there are "marks" on the spring housing, and a pointer on the part that moves. The pointer needs to be between the marks, or you will not have correct tension.
Old Apr 5, 2003 | 12:53 PM
OK, I'll check that out later and see if that's the problem...what if it's not between the marks, will I need a new tensioner?
Old Apr 6, 2003 | 12:53 AM
No... you will need a new, shorter belt. It's slipping.
Fred
Old Apr 6, 2003 | 02:27 PM
Fred
I can't find anything shorter than a 59" in a 6 rib though
RUENUF
Mar 13, 2016 03:37 PM
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
