quick 3.73 question
Old Apr 2, 2003 | 10:26 PM
QCKZ28's Avatar
quick 3.73 question
my car is in the shop getting gears installed. i have a couple of quick questions:
1. will my car shift right before i get the speedo fixed?
2. how much will the speedo be off?
3. with the speedo corrected 1st gear should redline about 40mph? and 2nd gear redline about 70mph?
4. how big of a problem will traction be on street tires in 1st gear?
thanks
jesse
Old Apr 2, 2003 | 10:49 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: quick 3.73 question
thanks
jesse
1. yes
2. ~18% (1+3.23/3.73)* showing speed = actual speed
(subsitute 2.73 in if you had those)
3. roughly depending of tire size. www.f-body.org/gears for exact answers
4 . huge
Old Apr 2, 2003 | 10:54 PM
Re: Re: quick 3.73 question
Originally posted by treyZ28
1. yes
Are you sure? Since the shift timing relies on the VSS and it is going to be wrong, how will it shift correctly?
QCKZ28's Avatar
thanks for the quick response... cant wait to feel the difference.
Old Apr 2, 2003 | 10:59 PM
treyZ28's Avatar
Re: Re: Re: quick 3.73 question
My car didn't shift right once, and then shifted perfectly every time.
Old Apr 3, 2003 | 02:19 AM
1982z28with18s's Avatar
Shift points are based on speed. Your tranny will shift, but don't expect a WOT shift. Heres why...The computer will think you should shift out of 1st at around 48mph(assuming 2.73's), but you will set off your rev limiter around 40mph. It will shift fine at partial throttle, but you can't really race it until you get it programmed. I know this because I just got 3.73's, and drove around for a day before I got my hypercrap programming on my car. Traction in 1st will be gone. I had 275 good year f1's and I could launch easy and good, but once I hit about 4,000 rpms in 1st I broke loose and kept spinning until I shifted into 2nd. Now with the 315 nitto drag radials I can finally keep some traction in high rpms in 1st. Just get it programmed and learn to love the gears. One of the best mods I have done so far.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
