low engine coolant
Old Apr 2, 2003 | 09:02 AM
street demon2k3's Avatar
low engine coolant
i need help, my low engine coolant stays on. i recently drained and changed the coolant along with the coolant sensor located on the water pump. what should i do???
Old Apr 2, 2003 | 09:06 AM
Terran2k's Avatar
i think you're supposed to changed the coolant level sensor on the radiator....its a couple inches below the radiator cap.
Old Apr 2, 2003 | 09:07 AM
Thebeast431's Avatar
The low coolant sensor isn't on the waterpump, its right next to the battery about 3 inches below the radiator fluid cap. Just unplug the sensor to get rid of the light, I have had mine unplugged for 2 years now, no problem. Just check your fluid every week. You can buy a new sensor, but I wouldn't worry about it.
Travis
Old Apr 2, 2003 | 07:45 PM
kirschman's Avatar
like said above, all ya gotta do is unplug it. Mines been unplugged for bout 3yrs., no light or probs.
Old Apr 2, 2003 | 08:20 PM
ollie-99's Avatar
i unplugged mine and it still stayed on!?
Old Apr 3, 2003 | 12:37 AM
bigfoot2471's Avatar
my 94 z also has a problem with the low coolent light. i will have to try and see if unplugging it will shut it off. i am just wondering if this is a common problem for this year. or just for the f-body in general.
Old Apr 3, 2003 | 06:57 AM
RENE95Z's Avatar
I had my low coolant light come on and topped off my radiator and it was still on. Checked the level in the overflow and it was low, topped it off, turned off the car and then turned it back on. No light and no problems since.
Old Apr 3, 2003 | 08:30 AM
ledfootz28's Avatar
i have a 94 and i drained the fluid with no problem,still plugged in.
Old Apr 3, 2003 | 08:31 AM
Euclid's Avatar
Despite popular belief, you don't have to leave the sensor out, or replace it either.
Once you have it out, clean it. Most likely it will be so disgustingly dirty that it can't read the fluid.
Clean it pretty well and put it back in.
Start the car, light should be gone.
Old Apr 3, 2003 | 08:32 AM
It's common for all. Unplug, clean (may work) or replace are the options.
calaban
May 18, 2020 06:43 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
