Installing driveshaft Safety loop and have a question
Old Apr 2, 2003 | 07:27 AM
RealQuick's Avatar
I am putting on my ds safety loop. After I unbolt the ds from the universal joint, and put the dssl on, what torque do I use when putting the ds back on? Is it 50ft-lbs?
Old Apr 3, 2003 | 06:12 AM
RealQuick's Avatar
Nobody?
Old Apr 3, 2003 | 06:20 AM
Are you talking about the caps that hold the rear u-joint to the pinion yoke? Chilton's shows those bolts at 16ft-lb. Definitely not 50ft-lb.... that would crush the needles.
Old Apr 3, 2003 | 06:37 AM
RealQuick's Avatar
I believe so. I am just unbolting those caps to remove the ds, slip on the safety loop and bolt it back up. I have the chiltons, but wasnt sure if I should use the 16 or 50 ft-lbs. So 16 for the caps?
Noenav
Mar 1, 2019 07:38 AM
Jan 23, 2015 01:13 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Red97LT1
Sep 7, 2002 09:29 PM
Chrisdude
Jul 24, 2002 02:25 PM
