rear intake oil leak
Old Apr 2, 2003 | 02:44 AM
chasmanz28's Avatar
is it common for a Lt1 motor that only has 17k on it to be leaking oil from the rear intake, give me sum input as to why its leaking, or is it normal, and should i buy gm gaskets, or is there a better gasket out there that i can buy so this doesnt happen again, thanks chas
Old Apr 2, 2003 | 03:01 AM
FastGuyJR's Avatar
Intake leaks happen all the time. You may want to double check that it's not your oil sender unit leaking. The car may only have 17000 miles but it's still at least 6 years old. If it is in fact an intake leak, buy yourself some GM LT1 intake gaskets and some black RTV. Clean the surfaces very well, using carb or brake cleaner, towels, and a razor blade, or it will be sure to happen again. The dealership around here uses GMS (?) instead of RTV, I think because it's made by GM. There is probably better documentation around, but I hope this helps.
JR
Old Apr 2, 2003 | 03:04 AM
chasmanz28's Avatar
JR
yes it is an intake leak from what the dealership told me thanks for your input.
Old Apr 2, 2003 | 08:24 AM
Bastardcat's Avatar
This leak is a very common problem. Here are some links if you're going to tackle the job yourself:
http://www.projecttransam.com/projects2.asp
http://www.bfranker.badz28.com/fbody/intakefix.htm
Old Apr 2, 2003 | 08:29 AM
93zder's Avatar
Did you get a quote from them as to how much it will cost to fix it - how many hours labor?
Old Apr 2, 2003 | 12:10 PM
chasmanz28's Avatar
yes they said 4 hours so after all said and done its going to cost 400 hundred freakin dollars so im upset that it happened with only 17k on the motor so im going to do it myself and take my time i hope i can handle it lol thanks for the site on how to do it bastardcat
HectorM52
Jul 30, 2017 11:46 AM
artic94
Jan 17, 2015 11:19 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
