what is necessary for a cam!!
Old Apr 1, 2003 | 01:17 PM
97BLKZ28's Avatar
Talking what is necessary for a cam!!
ok ive now decided to go with the cc-305 cam, i am also replacing the spirings lifters, and retainers. do i need to put a new timing chain on?
is there anything else i need to keep in mind that i should replace while im doing the cam job?
Old Apr 1, 2003 | 01:22 PM
lt1HULK's Avatar
You will need to replace gaskets and whatnot. Also, while you are in there, you might as well replace your rocker arms. You will get more gains out of your cam, and it will sound better
Old Apr 1, 2003 | 01:33 PM
1997rblckSS's Avatar
Re: what is necessary for a cam!!
Timing chain would be a good idea, I have no recommendations though, I have an LT4 heavy duty timing chain that I don't like due to how tight it fits. Might want to go with RR's 1.6, to get the most lift out of the cam you are purchasing, it will open things up better.
Do you have headers?? What about a bigger TB? You want to get the most benefit from the cam as possible.
Old Apr 1, 2003 | 01:49 PM
twells's Avatar
double roller timing chain wouldn't be a bad idea, along with an electric wp. you will need all the gaskets and you might wanna get a 1le elbow and some tuning
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
