I'm pretty sure oil from PCV is causing my misfire! What should I do???
Old Apr 1, 2003 | 09:22 AM
asianice25's Avatar
Unhappy I'm pretty sure oil from PCV is causing my misfire! What should I do???
I have been reading about the oil getting into the intakes of our cars, and im just wondering what to do about it. Some people are putting fuel filters inline, but i think they would get clogged a lot. the catch can looks good, but what about just unhooking it and venting to atmosphere? Would this trigger any codes? This is really pi$$ing me off, i have a $27,000 piece...
Old Apr 1, 2003 | 11:08 AM
NEWBIE T/A's Avatar
Thumbs up Here's a possible solution !
Look at the first article here:
http://www.ls1howto.com/
Perhaps there was a step you missed ?
Good Luck !
Britt
Old Apr 1, 2003 | 11:37 AM
NEWBIE T/A's Avatar
Lightbulb I found the one I was REALLY looking for the first time !
See:
http://www.fbody.com/members/stevenm...ML/pcv_mod.htm
WEb Site for other possible good tidbits is here:
http://www.projecttransam.com/projec...Type&Value=LS1
See ya !
Britt
Old Apr 1, 2003 | 01:05 PM
asianice25's Avatar
OK, so I just started my car at lunch and its running fine now. I swear, this things is the nicest looking piece a crap in the world. I've also decided what im going to do about this. Im going to get a new catch can with one inlet and the breather on top. Then Ill hook a hose from the pcv valve to the can, vent to atmoshpere, and plug the intake. How does this sound? Ive read of people doing this and it working fine. Does anyone know if itll set an codes? I guess if it doesnt work ill be out about 60 bucks. oh well.
Old Apr 1, 2003 | 02:50 PM
Camarocks's Avatar
Do this mod and you should be better off.
http://govettego.com/mods/pvc/index.htm
Old Apr 1, 2003 | 02:53 PM
asianice25's Avatar
Why would this be better???
Old Apr 1, 2003 | 02:55 PM
Camarocks's Avatar
The filter won't clog, just empty out the little can every once in a while. It's better than having that oil go through the intake.
Old Apr 1, 2003 | 03:15 PM
JasonD's Avatar
Admin Emeritus
Question
I wonder if those who have the LS6 block need to do this?
Old Apr 1, 2003 | 03:17 PM
NEWBIE T/A's Avatar
Talking Rub it in, why doncha !!
I have the Bullseye on my '99 !
Surprise, huh ?
Britt
Old Apr 1, 2003 | 03:22 PM
asianice25's Avatar
Well, I wasnt just going to use a breather filter. I was going to cap the inlet on the intake manifold, and run the pcv valve to a catch can with one inlet only. the result is the same as this mod, except ill be venting to atmosphere. Have you eve had a problem with you car doing this? i have a few posts going right now cause my car is really messed up. I switch the pcv from the 2002 Z06 i had in to a new stock Z28 unit, and the car starts dropping cylinders like crazy. is this just coincidence? is it really a bent pushrod or cracked spring? I have no idea, but this seems to be a bit more than just a coincidence. I need to get this fixed and fixed right the first time(i hope)...
Old Apr 1, 2003 | 03:33 PM
asianice25's Avatar
so who has the first hand experience with what im dealing with here? Anyone? Anyone ever vent this crap to atmosphere? what is it going to do?
Old Apr 2, 2003 | 11:40 AM
asianice25's Avatar
Alright guys, I decided to go with the line filter for an air compressor. Before I do it though, Im going to clean the top end with my gm top end cleaner. So heres my question. where is that air valve at that I need to disconnect? Do i have to disconnect it?
Old Apr 2, 2003 | 12:39 PM
MARSTAUT's Avatar
I can't get this site to work for ****. Is there another place that has the instructions for this mod.
Also whats the part # for the Z06 PCV
Old Apr 2, 2003 | 01:17 PM
asianice25's Avatar
Im not sure whats wrong with this site, but it works fine for me. Im not sure of the part #, but just go to the dealership and ask for a pcv for a 2002 Z06. It cost me under 4 bucks. not bad. Basicall this sites saying to put a air line filter/dryer inline with the pcv. it shuldnt be too hard, i think this will be the cheapest way to go, and with the clear tank you can see where the levels at. I think im going this route, instead of a catch can. I think the catch can would look nicer, but i can change it later. At the home depot the parts will cost around 15-20 for the filter, and a few bucks for the fittings. I may get the swivel fittings though, they cost like 14 a piece, still not bad though.
Klypto
Mar 23, 2016 09:05 AM
PCLZ28
Dec 24, 2015 05:19 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
