How exact should pushrod length be?
Old Apr 1, 2003 | 02:01 AM
allmotorta's Avatar
I was told in another thread that in order to decide what pushrod length would be right for my setup is to subtract the total milled off my heads, and the difference in head gasket thickness.
Example: Stock pushrod is 7.200". I'm milling my heads .030. So subtract .030 from 7.200 and get 7.17. I'm running impala head gaskets which are .020 thinner than stock, so subtract another .020 from 7.17. Total is 7.15. Thats the length I should shoot for. So what would be an acceptable range to run? So far I've only seen 2 sizes for sale, 7.20 and 7.13, there's probably more out there, but I haven't looked very hard yet. I want them hardened BTW. The setup is: stock ported heads, cc306, new oem GM lifters, 1.6 rockers. So what size would be acceptable to run? Thanks!
Old Apr 1, 2003 | 02:25 AM
jonaddis84's Avatar
I would think that as long as you are reasonably close you will be fine, since thats what rocker adjustment is for, you will be able to compenstate there.
Old Apr 1, 2003 | 10:51 AM
allmotorta's Avatar
Thanks! So if you were me, would you go with the 7.13 or stock length 7.2's?
Old Apr 1, 2003 | 09:34 PM
jonaddis84's Avatar
Id go with shorter just incase you might have valve cover clearance problems with a longer pushrod.
Old Apr 1, 2003 | 11:58 PM
allmotorta's Avatar
Thanks! I'll go with 7.13's then
13qtr
Oct 28, 2016 08:11 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
surreybrad
Sep 29, 2015 09:00 PM
