Am I a factory slug?
Old Mar 31, 2003 | 02:42 PM
95TA8280's Avatar
Unhappy Am I a factory slug?
OK mods and dyno numbers are below....those #s don't include my cutout (it was closed) the KM and airfoil.....I also dyno'ed up to 5800 RPMs, so I guess if I went to around 6200 I would've been a few higher.
However I am seeing people with similiar mods with like 320 HP and such, why am I so much lower? Before my cam kit, I was at 276/325. Should I be even higher?
My A/F is as follows........right at around 13 at 2600 RPMs...by 4000 it's at 12, and by 5600 it's at like 11.2. How much HP is this costing me? I'm also hoping I was getting knock, and my KM will help it out......what else could be causing my sluggishness?
Old Mar 31, 2003 | 02:49 PM
DarkHorse's Avatar
Those numbers do seem low considering what most people are reporting with the hotcam. How are your plugs/wires, general tune-up items? Good gas? Rockers adjusted properly? Just some things to check on.
Old Mar 31, 2003 | 02:56 PM
94SLUG's Avatar
Im the SLUG With no head work 50hp is not bad from cam only.
Old Mar 31, 2003 | 03:04 PM
95_RipperZ's Avatar
Ya those numbers seem low. Not super low but low. You should be seeing around 320/340 is my guess. Like darkhorse said, chekc out that stuff and make sure everything is in tune. Something little can make the difference.
Old Mar 31, 2003 | 03:13 PM
95TA8280's Avatar
During the cam install the opti, water pump, plugs and coil were switched. The plugs have about 7000 miles on them.
Would ignition problems cause any of this? I think I MIGHT have a small tear in my stock 1LE (whatever the stock one is called) but I don't think the tear is where air is going through.
Anything else?
Old Mar 31, 2003 | 06:39 PM
EviLBoX's Avatar
I bet if you uncapped your cutout you would gain another 10 rwhp or so. Flowmaster isn't exactly the best catback to use on high horsepower car, I gained 1.5 MPH in the 1/8th mile with my cutout open over my old Flowmaster exhaust. As you can see I've since then replaced my Flowmaster.
Old Mar 31, 2003 | 06:43 PM
95TA8280's Avatar
Yea I'm going to uncap my cutout my next dyno.
But it was open when I did 275 before the cam install? How much would my A/F (numbers above) affect my HP?
Novo
Jun 14, 2016 02:58 AM
magman
Apr 15, 2016 03:08 AM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
Stephen68
Oct 16, 2015 03:50 PM
football4life
Oct 4, 2015 07:48 AM
