Changing Cam Springs...
Old Mar 31, 2003 | 12:11 PM
Wild1's Avatar
I'm going to bury my old thread and start a fresh topic. Ok, the arguement is convincing to change the springs with the 1.6 Roller Rocker upgrade. I will buy a set that will work with the CC503 that I want this summer. That brings a few questions...
1 - I read on www.streetillusionsracing.com about changing the springs. They just put the piston to TDC and changed out the spring. I've got tight headers on here and I will not be able to inject air into that piston. Can I put the piston at TDC and still change out the valve?
2 - Will I need to shim the head spring seat beyond the shims supplied in the spring kit? I will not have any way to test spring pressure. Will the out of the box springs work ok?
3 - What is the recommend spring installer tool?
Old Mar 31, 2003 | 12:28 PM
Smoke T/A's Avatar
1. Yes you can change all the springs just by following the firing order by rotating the crank 90* after you reach TDC #1. This way if the valves drop they will hit the piston and not go all the way down in to the cylinder.
2. It’s always a good idea to check the installed height of the springs. The open and closed pressures depend on what height you set them at.
3. Snap on makes a great tool or you could even go to sears and get a cheap craftsman OHV spring compressor. (I have 2 if you want to buy one from me)
Also I would recommend going with the crane 10308-spring kit. It comes with shims, retainers and locks. They are good for up to a .600 lift and 7000-RPM HTH
Joe
Old Mar 31, 2003 | 12:43 PM
Wild1's Avatar
1- Great idea! If the valve does fall, can the spring and retainer still be put on the valve or do you need a magnet or sometype of tool to hold the valve in place while the spring is being installed.
2 - How do you check the installed height of the springs? Sounds simple. What would be the spec for a stock cam? I'm doing the head port and cam swap over the summer.
3 - How much is the Snap-On tool?
Old Mar 31, 2003 | 05:45 PM
Wild1's Avatar
What do I do if the valve slides down? Even if the piston is at the top dead center... can I still get the spring and retainer back on the valve or do I have to "fish" the valve out of the head.
Old Mar 31, 2003 | 06:10 PM
FTC's Avatar
FTC
1. yes, you can change it with the piston at top dead center. i just did this last week. the valve will drop maybe .5" max. get a small telescoping magnet, it will come in VERY handy for the retainers.
2. couldnt tell ya.
3. i had lots of trouble with the KD spring compressor with a crank top. it didnt have big enough teeth to grab both springs and the inside one wouldnt compress. get the moroso one from summit. its a lever style and will work on all springs. by far the easiest to use.
Old Mar 31, 2003 | 06:34 PM
kirschman's Avatar
I just did mine, used the compressed air method, only way to do it. I had my manifolds off so it made it easier. If u use the TDC method u will have a hell of a time holding the valves up to get the keepers on. Why fight all that when the air method is super simple, no worry bout valves falling down. On a side note, I used cmotorsports double springs. My spring compressor wouldnt catch the inside spring. Listen to this ghetto fix. I used a few heavy duty wire ties to hold the inner spring to the outer one and once I got em on just cut em off. Worked perfect. Heads where on the car by the way. U can use the "lever" type compressor on all but the back 2 cyl. then u got to use the screw type.
Old Apr 1, 2003 | 11:28 AM
Wild1's Avatar
Great input! Thanks!! I've heard about problems with the Sears compressors... that Snap On is the best. Anybody have any experience with Snap-On?
IgorT.455/406
Mar 12, 2015 03:39 AM
armedtrigger
Feb 24, 2015 08:30 PM
blac94Z
Feb 18, 2015 11:36 AM
birdblack
Dec 30, 2014 06:59 PM
