Is it really important to flow match the inj?
Old Mar 31, 2003 | 06:56 AM
Highlander's Avatar
Is it really important??? Will it make a huge difference... the price difference is rather big...
Old Mar 31, 2003 | 08:55 AM
Gripenfelter's Avatar
I just went with 8 SVO injectors. But you're running a blower too.
How much boost?
Old Mar 31, 2003 | 11:09 AM
Highlander's Avatar
9-10 psi
Old Mar 31, 2003 | 11:34 AM
Just a thought.... a 3.5% variation on injector flow can alter A/F ratio on that cylinder by 0.5 A/F units. On an NA setup, you would lose some power, but probably do no damage. On a major power adder, leaning out by 0.5 A/F units could cost you a piston. Or, you will see signs of detonation on that plug when you are tuning, and have to richen up the mixture to protect the engine, losing power on the other 7 cylinders..... unless you have a setup that can tune fuel and/or timing on an individual cylinder basis.
Old Mar 31, 2003 | 11:37 AM
Highlander's Avatar
3.5%? Is that the variation??? DIdn't know it was that much.. I thought it was ± 0.1 #...
I see the point... so its an extra insurance...
Old Mar 31, 2003 | 01:40 PM
I'm just throwing out numbers..... I had a set of stock RP injectors cleaned and flow matched by TPIS, and at least one of them had a serious problem, and had to be replaced. It flowed way low.
What kind of injectors are you buying? I thought when I dropped $200 on a set of SVO's from IRS a few years ago, that they were advertised as "flow matched"??????
Old Mar 31, 2003 | 01:44 PM
Highlander's Avatar
I am in search of some 50s
Formula Steve
Sep 19, 2023 08:31 AM
canuck94z28
Aug 19, 2015 05:50 PM
Slayer
Aug 17, 2015 03:55 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Boss002
Jul 24, 2015 10:47 AM
