When installing water pump..
Old Mar 30, 2003 | 11:27 PM
96z's Avatar
96z
Do guys use anything besides the gaskets like RTV, etc?
Old Mar 30, 2003 | 11:30 PM
tryme96Z's Avatar
Re: When installing water pump..
I used a little rtv and the wp gaskets. The RTV was light, just enough to hold the gasket in place.
Old Mar 30, 2003 | 11:50 PM
93midnightta's Avatar
you have to put some teflon tape/liquid on the water pump bolts themselves as well.
Old Mar 30, 2003 | 11:53 PM
96z's Avatar
96z
Really, I didnt know that, should I wrap the whole bolt than?
Old Mar 31, 2003 | 09:56 AM
96z's Avatar
96z
Dumb question I know but can anyone help me out?
Old Mar 31, 2003 | 09:58 AM
Just on the threads.
Old Mar 31, 2003 | 10:19 AM
Lunarson's Avatar
Just out of curiousity, why put that tape on the threads? I'm assuming the bolt hole has a bottom and doesn't screw into a waterjacket or anything does it? Anyway, I was just wondering because I've never used any to this point.
Old Mar 31, 2003 | 10:32 AM
i believe they do go into the water jacket but shoebox would know better then i.
Old Mar 31, 2003 | 11:11 AM
MZK4252's Avatar
I am positive that the two bottom bolts go into the water jacket; If you don't drain all of the coolant when you pull 'em thats where it drains from.
Old Mar 31, 2003 | 12:05 PM
96speed's Avatar
I use RTV on the bottom 2 bolts, and Loctite on the others.
Ryan
Old Mar 31, 2003 | 04:43 PM
Hyperspeed97z28's Avatar
I didnt use anything on my bolts?? just some RTV on the wp gaskets... should I be fine ?
Old Mar 31, 2003 | 05:15 PM
Actually, I didn't use anything on mine either and it has never leaked a drop.
It is a good idea, though, to use a sealant on a bolt that goes into a water passage or is not in a blind hole.
Nov 18, 2023 07:21 PM
RUENUF
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
jasonduaine
Mar 7, 2015 09:44 AM
Queens94z28
Dec 20, 2014 09:11 PM
