Installing a CSI Pump have a ?
Old Mar 30, 2003 | 04:10 PM
funina91ss's Avatar
I think I am going to use this guide I found in a search but my ? is on the diode is there a part no or name for it.. or are they all the same? and on the spdt switch it will run the pump when the motor is off. and key off right.. thats what I want and I also want the pump running only when the motor is running if the switch is off.. thanks Sean
Old Mar 30, 2003 | 04:34 PM
T/A#4's Avatar
May I ask, how many HP is this swap suppose to bring ???
Doesn't the install instruction explain this? I may do this if the "gain" is worthwhile ??
Old Mar 30, 2003 | 04:52 PM
funina91ss's Avatar
I fixed the link.. it has a hp and tq dyno on it..
Old Mar 30, 2003 | 05:00 PM
Lunarson's Avatar
Roughly 10 rwhp dynoproven gain in the upper rpm range. I think the key would have to be on for the pump to run with the engine off but am not 100% sure.
Old Mar 30, 2003 | 08:06 PM
97FormulaWS-6's Avatar
Go to radioshack and look for a 1N400x any of that series of diodes will work in that location.
Old Mar 30, 2003 | 08:17 PM
Markolc's Avatar
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
HectorM52
Jun 23, 2016 08:42 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
lbrowne
Nov 13, 2011 04:25 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
