What valve springs for 383?
Old Mar 30, 2003 | 12:28 PM
gb95zconv's Avatar
What spring should I run on my 383 setup? Right now the cam is going to be a cc305(might change to a 224/230). The heads are ported stock with 1.6 rr. I have some lt4 springs which will work with the 305 but not the 224/230...I belive the lt4 springs have a 101# seat pressure and a 330# rate. I also have some crane dual springs with a 130# seat and a 395# rate. I just dont want to use more spring than I need and hurt hp. I plan on spraying a 150 shot also so Im leaning towards the crane dual setup. Any thoughts ?TIA
Old Mar 30, 2003 | 12:30 PM
Beast96Z's Avatar
Use the cranes or some Comp 987-16's. You'd rather have more than not enough.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
