How much refrigerant to fill A/C?
Old Mar 30, 2003 | 11:55 AM
Don 97 SS's Avatar
Question How much refrigerant to fill A/C?
I emptied my A/C lines on my 97 doing some work and need to refill the entire system. How many cans of refrigerant do I need? Is one brand better than another? Any special refill tips or recommendations?
Old Mar 30, 2003 | 01:02 PM
Eddie95Z28's Avatar
Re: How much refrigerant to fill A/C?
It says it right on the radiator thing... I think it is 24oz. Did you open the system? like disconnect any lines. If you did you will need to have the system evacuated. you can't just fill it up. In that case I would recommend just taking it to a shop.
Old Mar 30, 2003 | 01:08 PM
gb95zconv's Avatar
Its about 2 cans.....I just filled mine up and it was fine......Im sure evacuating it would be better as well as a new dryer....but hey ...my mods tapped me out.
Old Apr 1, 2003 | 09:47 AM
Don 97 SS's Avatar
Re: Re: How much refrigerant to fill A/C?
Thanks, guys. I later found that it needs 2lbs.
Yes, I opened the system to do a cam swap. Tell me more about the "need to have the system evacuated". I don't understand that. Why can't I just refill the system with some 134 and some special oil?
Old Apr 1, 2003 | 09:58 AM
gb95zconv's Avatar
Re: Re: Re: How much refrigerant to fill A/C?
The system gets moisture in it when opened that can degrade the components....the dryer will prabably take care of it for you(round silver cylinder mounted to fender wall). The oil is in the can with the r134...just fill and go...you should be ok.
Old Apr 2, 2003 | 09:39 AM
Eddie95Z28's Avatar
Re: Re: Re: Re: How much refrigerant to fill A/C?
If you say so. The system needs to be drawn to a vacuum so it will get the full amount of R134a and ONLY R134a. Moisture in the system can freeze and cause problems. It is just the better way to do it.
Old Apr 2, 2003 | 05:30 PM
smokindastangs's Avatar
Yeah, I did the same thing. So how much will it cost to get the AC hooked up to a vacumm so i have no issues w/ ice?
magman
Apr 15, 2016 03:08 AM
Pwilson59
Sep 3, 2015 08:47 PM
WPHIG2
Aug 27, 2015 06:37 AM
malikot02SS
Aug 15, 2015 01:11 PM
MikeWhitener
Aug 2, 2015 06:17 PM
